Question about Toro Lawn Mower With Toro Power Tools
Cable traction needs adjusted
I have a Toro 22 Recycler Model No 20041. I just replaced the cable traction but it seems loose. Is there any way to adjust it or should it be loose.
  • drwsmail Mar 27, 2009
    amajors1, can you please post an answer to how to replae the cable traction? We can't find that answer here.
  • 24 Answers
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Posted on Feb 05, 2009
How to repair a clutch cable on a toro recycler mower
Did the cable break? Or did it just stop working? In general you have to figure if it came off, break or did the adjustment slip. Readjust if necessary or replace the hole cable or re install it correctly. Simple Question, so many answers. And if all else fails, take it to a lawn mower repair shop.
Aug 21, 2014 | Toro Lawn Mower With Toro Power Tools
Can you tighten the belt that engages the blade?
check for a spring loaded idler pulley that keeps tension on the belt out of place.
May 17, 2013 | Toro Garden
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
Toro 6.5hp 22" Recycler model#20072 Self-prpel
John, adjusting the cable would have been my first suggestion as well, there are two screws accesible from under the deck to get the black cover off (one of them is in a corner and may be hard to see). Once you get the cover off you may be able to see if you may have a tension problem, belt problem, etc. Goodluck!
Apr 22, 2011 | Toro Power Lawn Mower
Toro 22" recycler Mod
Got the same problem with mine, replaced the drive belt, removed the wheels and checked for rocks and pebbles, greased, checked also bottom of gearbox. grease was present no broken teeth, top pulley has excive side to side play. Have not disaasembled yet. Hope someone would have had a solution here.
Apr 11, 2011 | Toro Lawn Mower With Toro Power Tools
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
Toro electric start won't start manually
If it doesnt start manually,you have another issue to deal with. Whether it has electric start or not you should be able to manually pull start it. You can also get the model and serial number off the engine and contact your nearest toro dealer to have charger and key ordered. As far as a push button,it can be done,just a matter of finding someone to install one for you.
Jun 03, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,919 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Dwain Pippen
Are you a Toro Garden Expert? Answer questions, earn points and help others
