Question about Rowenta IS9100 1550W Precision Valet Commercial Garment Steamer w/ Retractable Cord
How to open case on rowents commercial garment streamer as hose clamp let go
Hose came off, need to reattach and tighten up hose clamp. But can only do this by getting inside
  • judy syme Jan 20, 2013
    no but thanks anyway
  • 299 Answers
I had to open the case on mine to replace the "joining element" which is the plastic part that connects the inside hose to the external hose and wand. Here's how to get inside: 1. Remove the aluminum uprights by unlocking the tabs on the bottom of the unit; 2. Using a long Phillips Head remove the screw in the bottom front center of the base; 3. Remove the screws from the inside of the Accessory holders; 4. Pry up the wheels and they will snap off without damage; 5. Remove the screws that were covered by the wheels; 6. Pry off the black side panels with a flathead screwdriver. They're on pretty tight but once you get going they'll pop off; 7. Remove the six screws at the corners and sides holding the upper and lower shells together. NOW you have access to the hose clamp and everything else. NOTE: The screws in each step are different so keep them sorted by step to make it easier to reassemble.
Posted on Apr 24, 2015
    Genius:
  • 1,669 Answers
Get some help here:
http://www.rowentausa.com/rowenta/frame.aspx?page=http://www.rowentausa.com/rowenta/consumer_care/consumer_care/consumerCare.aspx
or here:
http://www.appliancepartspros.com/search.aspx?q=rowenta%20iron%20parts
Posted on Jan 20, 2013
How to take hose off rowenta professional garnmet steamer
http://laundry.manualsonline.com/manuals/mfg/rowenta/rowenta_iron_product_list.html
Aug 13, 2014 | Rowenta Commercial Garment Steamer - White
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Jul 08, 2014 | Rowenta Commercial Garment Steamer - White
How to open is 9050 rowenta precision valet to descale
Well this was helpful but also HELLfull! I guess because I have a 9050 !! I took out the screws & could not remove the hose it was attached with 2 clamps & a washer! I put the whole darn thing in my tub ( I have a sprayer in there) and yes tons of sand, black stuff and cloudy water came out. I had to do this 8 times with the hose attached! Awkward & a mess but it did finally come out clear. BTW I did it through the hose & the bottom hole. On the last run through, after my whole bathroom is soaked including me, the hose popped out! I was cracking up! turns out on the 9050 you simply push down on the ribbed hose covering and it releases. This IS NOT in the manual either. But I'm happy my steamer's like new again & live & learn ;o)
Oct 09, 2012 | Rowenta Commercial Garment Steamer - White
How to unclog a garment steamer
Hi, Try puting a cup of white vinegar in and let it sit over night. It should disolve the build up of calcuim. Also try CLR it also will work. Good luck.
Nov 04, 2011 | Rowenta Commercial Garment Steamer - White
How do i open d rowenta garment steamer to change the fuse or burnt wires
There are four screws (Phillips) but you need long thin screw driver to remove them. Then there are TWO screws underneath the Castors. Just pop the Castors and turn them and you will see the screws. BTW there are two fuses inside. One you can replace and the other one is soldered in and you need to be little skilled to replace it. Chances are if the first one blew the second one should be OK. Good luck.
Jul 04, 2011 | Rowenta Commercial Garment Steamer - White
MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER PRODUCES STEAM. WHAT MIGHT BE WRONG AND HOW CAN I ATTEMPT TO FIX IT?
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
Dec 04, 2010 | Rowenta Commercial Garment Steamer - White
Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
May 19, 2010 | Rowenta Commercial Garment Steamer - White
Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Oct 10, 2009 | Irons
Rowenta IS9100 1550W Precision Valet Commercial Garment Steamer w/ Retractable Cord Logo
772 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
