Question about Invacare Health & Beauty
Left Brake fault
I'm helping a Veteran that the VA administration has left hanging. He has an InvaCare power chair TDXSP. The controller is showing a "left brake fault". I unplugged both motors from the power control box on the bottom back of the chair and reversed them. Then it said I had a "right brake fault" when I powered it up. I see a couple of solutions here about replacing the left motor assembly under this same question. Would this still be a solution for this problem or is it the motor control box that they are plugged into need to be replaced?
  • Strat McCloskey Jan 22, 2013
    Pardon the earlier incomplete post. I didn't realize you shouldn't hit ENTER when posting on this website. Here's the complete post...I couldn't identify any brake cable going to the motors from that controller mounted on the bottom of the rear of the chair. Each connector has 2 heavy wires to one of the motors and 2 thin wires that go to a switch in the rear of the motor that tells the machine whether or not the motor it is in the drive or push (free wheel) mode. When you switch the motor cables on that controller you get a motor fault that follows that particular motor cable. When you set the motor levers to push (free wheel) you get left brake fault. When you set levers to drive you get a right motor fault. Hope this makes some sort of sense. Strat
  • Invacare Master
  • 1,263 Answers
Hi, Please check the lead and the fitting to the controller, it 's rare for the controller to have this problem, I have repaired that very fault recently and it was a high resistance cable fault , now measure the brake cable from the controller , disconnect cable and put the electrical meter on the lowest ohms reading, now it should read from 0.4 to 1.0 ohms any more and that's what causing the problem.
Regards
Posted on Jan 20, 2013
  • 8 more comments
  • Strat McCloskey Jan 20, 2013
    I will try that tomorrow and post the result. Thanx.
  • Strat McCloskey Jan 21, 2013
    I couldn't identify any brake cable going to the motors from that controller mounted on the rear bottom of the
  • Robin Hill
    Robin Hill Jan 22, 2013
    okay it normally combined with the motor output from the controller, there should be four connectors within the one connector , two for the brake and two for the motor
  • Strat McCloskey Jan 23, 2013
    I don't know if you had read the whole post concerning the cables. Here's some additional observations that were made yesterday. When the chair was turned on the display read that the chair was ready to go (not those exact words). When the joystick was moved the errors then showed up. eg: right motor fault. Hope this might shed some light on where the problem is.
  • Robin Hill
    Robin Hill Jan 23, 2013
    hi, once you move the joystick the controller will then test the brake before powering , now as i explained earlier you need to make sure the resistance is correct otherwise it will never work . regards
  • Strat McCloskey Jan 24, 2013
    Hi, This is where I'm getting confused with the terminology. I don't see any type of "brakes" on the motor. I'm looking for some sort of a coil that would energize a braking mechanism and assume it's electronically braked through the controller. I removed the rear plate on one of the motors to see where the 2 smaller wires went after entering the motor and all that there is is a small switch mounted to detect whether or not the lever on the outside of the motor is in the up or down position. Indicating if the motors are engaged with the wheels or not (are you calling the action of these levers the brakes?). Is it this switch you believe is malfunctioning? I did check the resistance across the leads at the connector end and they didn't seem outta bounds. I will take another look based on your advice.
  • Robin Hill
    Robin Hill Jan 24, 2013
    Strat, I 'm going to have more detailed look and supply pictures shortly.. regards
    Looking forward to that. Thanx
    I have 3 pictures you can look at. You can just make out the 4 wires in the one that go into the controller(also pictured). you can see the motors and the rear 4 screws on them that when removed along with that plate show that switch behind there. That I don't have pictured though. Also a picture of most of the chair.
  • Robin Hill
    Robin Hill Jan 25, 2013
    hi, see the yellow strings to the left and right of those pictures are the motors, now you see three screws, they are the electro mechanical brakes fitted on top of the motor ? The wires going into this part need to be tested regards
  • 692 Answers
SOURCE: no forward or reverse. lights
Joe with a scooter there can be a number of things wrong to cause your problem Since the motor turns and you have power at the console. It could be the throttle pot or the speed pot or both or it could be the cable that runs from the console to the rear of the scooter and finally a problem with the controller. But that would also give some sort of error to the console light if it is equiped with a power light. If Medicare paid for your scooter then they will pay most of the cost of repair. Your provider can work on it for you or they can contact a repair service that will fix it for you Hope this helps
Posted on Sep 27, 2010
  • 346 Answers
SOURCE: We replaced brushes on motors
GOD I LOVE BEING HERE FOR PEOPLE LIKE YOU,PLEASE DOWNLOAD :SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 THAT WILL GIVE YOU WHAT YOU NEED,COLIN.
Posted on Mar 14, 2011
  • 692 Answers
SOURCE: I have a Invacare M91
Why not just lock the joystick. you can have the provider check the programming and you should be able to put it in lock mode then unlock it when you want to use it Hope this helps
Posted on Apr 20, 2011
e-Guru
  • 3917 Answers
SOURCE: gentleman was using the Storm
Hi
Please check this link for the fault code:-
http://www.ctmhomecare.com/PDF/Troubleshooting/Troubleshooting-PowerChair.pdf
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 03, 2011
undernet01
  • 492 Answers
SOURCE: invacare m51 power chair controller
I'm in a power wheelchair myself. If the wire coming out of your controller has a place in which it can be unplugged, you can try unplugging that, then plugging it back in. If that doesn't work, then you probably don't have the appropriate tools needed to reset the controller. You'd need to take it in to get serviced.
Installed new batteries Service Indicator Light flashing 5x Manual says problem is with Left Park Brake and says check L P B connections. How?
There is a lever on both sides of the chair they are there to make it easy to push the chair without power. both sides need to be in brake mode in order for the chair to operate. If the levers are locked in brake mode then the motor wiring will need to be checked that it is plugged into the controller. A Tech may need to be contacted to help with this.
Apr 03, 2016 | Electric Mobility Invacare Pronto M41...
My tdxsp wheelchair will not power off
This should help you: Invacare,s TDX - SP power wheelchair - YouTube
Sep 26, 2015 | Health & Beauty
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
Jul 15, 2014 | Electric Mobility Invacare Pronto M41...
I can't remove the seat from an Invacare Pronto M91 VA chair with elevating seat.
single post, lift handle to rotate then pull up very hard!!! four poster lock is between knees release tilt back and remove
Oct 28, 2012 | Health & Beauty
Help I stupidly got my dog lead caught around the left drive wheel of my M61 Pronto yesterday. A kind person got it unwound but needed to tip the chair on its side to do it. Now the far left single green...
The M61 has an elevating seat. There is a speed limit switch which consists of 2 magnets that make contact under the seat on the seat post. If the 2 magnets are together then the chair thinks the seat is all the way down. If the magnets aren't touching it activates a safety feature in the controls which cuts power to the chair by 50% hence drives real slow. Try lowering the elevating seat down through the joystick controls. If that doesn't fix it then either the magnet switches on the seat post came unplugged or broke.
Sep 16, 2011 | Invacare Supply Group Pronto M61 Standard...
Invacare Arrow power wheelchair, display says: right brake fault release JS. We've made sure the brake fault levers are in the up position for power drive. Chair will not move. What do we try now?
If you have made sure that the freewheel levers are in the drive position and after turning the power on and you are still getting the barke error then the motor and brake assembly will have to be checked by a tech and possibly have to be replaced There is no self fix for your problem Sorry Hope this helps you
Jun 25, 2011 | Invacare Pronto M51 Power Wheelchair
The left wheel will not move. The led light says left brake fault. How do I disengage the brake?
You can't You will have to replace the left motor/gearbox/brake assembly. The controller checks that you have a good signal from the brake and will not move if it doesn't get one disengaging the brake will not remove the fault and the chair will not move. If Medicare paid for your chair than they wil pay for repair. Contact the provider that sold you the chair and ask if they can repair it or contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to see if they can have a tech come out to repair your chair. Hope this helps you
Mar 17, 2011 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
288 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Louis Smith
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
