Question about Uniden DECT 6.0 Cordless Phone ID
The red blinking light telling me I have a message will not turn off and when I make a call I get a busy signal and then it makes the call
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Posted on Jan 20, 2013
My red light indicating I've retreived my messages will not stop blinking
This may be the cause of a couple other things, especially with an Android.
1. Charging phone makes red light blink
2. System problems may also cause your red light to blink
Mar 24, 2015 | Lands Phones
After thunder storm
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 06, 2014 | Panasonic TH Televison & Video
Started blinking and the red light blinking now and no tv screen when i turn on just blinking red power light
The blinking light is a self-test diagnostic. If you can tell me how many times it blinks in between each pause and what is the make/model of the tv, I can tell you whats the source of the problem.
Mar 27, 2011 | Televison & Video
Traction systen warning message.The right turn signal also blinks rapidly if turned on,both dashboard grenn turn signal lights also intermittently come together venture 2001.
traction system warning message.The right turn signal also blinks rapidly if turned on,both dashboard turn signal lights also on come together venture 2001.This happens when it is cold raining and the automatic head lights are on and the brake pedal is depressed.
Oct 09, 2009 | 2001 Chevrolet Venture
Where is the turn signal flasher on a 99 alero
THE TURN SIGNAL AND FLASHER ARE TIED IN TOGETHER.YOUR FLASHER SWITCH IS ON THE DASH.ITS A ROUND RED BUTTON WITH A WHITE TRIANGLE ON IT.WHEN YOU PRESS THE RED FLASHER BUTTON ON DASH.IT WILL MAKE YOUR FRONT AND BACK SIGNAL LIGHTS BLINK.WHEN YOU WANT TO TURN OFF FLASHER THEN YOU PRESS THE RED BUTTON.IT WILL TURN OFF FLASHERS.
Aug 10, 2009 | 1999 Oldsmobile Alero
Only red light bliking, no screen
the red blinking light is indicating that you have a missed call, unread message, or unread email.
which makes sense if you cant see the screen.
holding the power down for 5 seconds doesnt do anything?
how about pulling the battery and replugging it in and turning it on via the Red hangup/power button?
this is known as hard-resetting the handset.
if its under warrenty you might be able to get the screen swapped out.
Jul 14, 2009 | RIM BlackBerry Pearl Smartphone
Msg. Light
Did you change carriers lately? Some new services include carrier's voicemail and they sent a signal to turn on your systems light. Check with your carrier firs.
Mar 19, 2009 | RCA 25423RE1 Phone
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Uniden DECT 6.0 Cordless Phone ID Logo
70 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
