Question about Cameras
How do i change to automatic mode - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Turn the mode dial to the camera icon.
If you need a user guide or other documentation for the DSC-W70, you may download them from here.
Posted on Jan 20, 2013
When i turn phone on it pops up no network coverage
open your settings on that click phone settings now go to the network option and see whether it is in automatic mode or manual mode . If it is in manual mode change it as automatic mode . If still having problem then change your sim card and try if still having the problem contact your nearest service professional
Jun 19, 2011 | Cell Phones
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
How to change the tv mode. Its on AV mode and i want to change it back to TV mode
Hello
You can set the Game mode and External input mode at the same time by pressing the GAME button on the remote control. "GAME" appears on the TV screen. To exit the the Game mode and the external input mode, press the GAME button on the remote control again. To cancel GAME mode only, adjust the PICTURE control. The game mode will be set ot 'OFF" automatically. In this case "VIDEO" instead of "GAME" appeares on the TV screen. When you press the GAME button if the TV is off, the TV turns ON and will be in the GAME mode and external input mode automatically.
Nov 06, 2010 | Durabrand DWT1304 13" TV
Viewing mode reverts automatically to Dynamic fixed mode
Go to setup and reset to factory default. You will be asked the TV LOCATION (Store or Home). You must choose HOME. Hope it helps.
Mar 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The battery in my 2006 pontiac vibe went dead. I recharged it; however, the setting for the door locks changed. It now unlocks automatically when I turn the car off instead of when I put the car in park. I...
The 2006 Vibe no longer has that feature. It was discontinued after 2005. I have the 2005 so I know how to change it. If your 2006 is able to change then here are the directions from my 2005.
Programmable Automatic
Door Locks
If you have an automatic transaxle, your vehicle is equipped with an auto door lock/unlock feature which enables you to program your power door locks.
Your vehicle left the factory programmed to Mode 4.
The following is a list of the available programming options:
Mode 1: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. There is no automatic door unlocking.
Mode 2: No automatic door locking or unlocking.
Mode 3: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. All doors and liftgate unlock when the shift lever is moved to PARK (P) with the ignition on.
Mode 4: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. All doors and liftgate unlock when the ignition switch is turned from ON to ACC or to LOCK.
To change the mode you are in, do the following:
1. Set the interior lamp control dial to the door position.
See Interior Lamps Control on page 3-16.
2. Move the shift lever into PARK (P) and close all doors and liftgate.
3. Turn the ignition to ON.
4. Within five seconds after the ignition is turned to ON, press and hold the power door lock switch in
the lock position for about five seconds.
5. The interior lamp will flash to indicate that the mode has been changed. For example, if the lamp flashes once, the function has been changed to Mode 1.
If the battery is disconnected or run down, the mode is changed to the initial mode which is Mode 4.
Jan 22, 2009 | 2006 Pontiac Vibe
Automatic widescreen mode
If memory serves, no. If I'm wrong, the would be a setting in the menu or the remote to change it from 4:3 to Set by Station or Automatic. Might say Format.
Nov 07, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Canon Rebel xti - auto focus problem
AI should be focusing. You really can't change many settings when you are shooting in auto mode. Is the lens in AF mode?
I'm sure you have long since returned from vacation!
Hope this helps!
Dec 31, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Shooting modes
What is the best situation to use each of the shooting modes? The shooting modes are described as follows: Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Shooting modes
The shooting modes are described as follows: PROGRAM AUTO (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
