Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
Flame won't stay lit for more than ten seconds.
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Pilot won't stay lit...gaffers&sattler model B35
Hit the flame sensor next to the pilot with sandpaper. If it still doesn't work replace it.
Feb 26, 2013 | Heating & Cooling
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
IF error code on Hayward H150FDN
flame sensor if stands for ignition failure
May 16, 2012 | Hayward Pool & Spa
My water heater pilot light won't stay lit
you need to clean the filters in the bottom of the water heater and have the thermal couple also check and see if there is a gas leak by spraying all visible gas lines if this doesent work then you more then likely need a new watter heater
Jan 17, 2012 | Water Heaters
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
41 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
