Question about Taylor Bowflex Body Fat Scale
Resetting bowflex body fat scale
How to reset scale
kaivuitton
SOURCE: Body Fat Reading too high
Bring it back love..it's obviously ****..if u can not balance it out(usually there is a button) or reset the thing...bring it back and spend a lil bit more on something better..u seem serious about your body which is awesome so keep it up and replace the device
Posted on Jun 01, 2009
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
  • 12 Answers
SOURCE: I'm trying to find the
I just pulled my manual, as I recently started a slow carb diet and needed all my measurements. It was fun trying to find it. After finding nothing online (before my search), decided to post mine for everyone out there. It can be found under my photobucket album. Here is the link:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Posted on Jan 29, 2011
  • 12 Answers
SOURCE: I need an instruction manual
I posted the manual in my photobucket album here:
Amy
  • 12 Answers
SOURCE: Just purchased the Body Fat Scale but it didn't
I just uploaded my manual into photobucket, it can be found here:
Posted on Jan 30, 2011
My scale is a taylor 5751 bc how do i reset all memories?
Easy way is to remove the battery. Or individually;
Press and hold the "Power" button in the center of the scale. Your scale will then list the information you have saved for each memory number.
Hold both the "Up" and "Down" buttons for about three seconds. This will clear the information for that memory number.
Repeat the process for each memory number that has information stored on it.
Remove the battery from the scale. Leave it out for five minutes. Reinsert the battery to finish resetting your scale.
https://healthfully.com/reset-taylor-scale-5033705.html
Oct 05, 2017 | Taylor Health & Beauty
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    How do I reset the scale?
    If the scale is an electronic version, remove the batteries and wait a minute or two before replacing the batteries. That will probably zero the scale. If that doesn't work, it's time to buy new batteries.
    Jan 13, 2015 | Health & Beauty
    How do I reset my Health O Meter BFM588DQ-81?
    If the scale is moved, you must reset the scale back to zero in order to get an accurate reading.
    Jun 11, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
    I changed the battery and now when turned on all icons on screen flashing non stop
    try repeated pressure to reset (5-6 times in 10 sec) or could see if there is a small hole near battery compartment, push with paperclip (button reset)
    Jun 06, 2014 | Soehnle Exacta 63694 Body Fat and Water...
    I have a NOVA Weighing Scale model BGS-1212. I am not able to reset the weighing scale display. Please help
    i HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
    Oct 14, 2012 | Health & Beauty
    Need Bowflex scale instructions
    hi!! google model# to their web site and download the user manual
    then print it out. most are free
    Oct 03, 2012 | Taylor 5728-4072FBOW...
    Have a WeighMax postal scale..how to I cange from kg to pounds?
    I had mine set to ozs for over a year and then it changed to kg. Couldn't reset it by hitting the button, so I removed the battery and then put it back in. It reset it to ozs.
    Jan 15, 2011 | Precision Camera Weighmax Body Fat, Body...
    My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
    Reset it!
    Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
    Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
    Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
    Taylor Bowflex Body Fat Scale Logo
    462 people viewed this question
    Top Taylor Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
