Question about Husqvarna Zero Turn Mower RZ4619
More will start but will not run with e-brake off and in turn will not engage the mower blades
The mower will start when e-brake is engaged but will not stay running as soon as it is disengaged. is this a Voltage issue???
  • Husqvarna Master
  • 2,239 Answers
No, this is a micro switch issue, to prove this find the single black lead coming from the ignition unit ( cut out wire ) and diss connect it and try again, be aware it will not switch off at the ignition switch with this wire not connected.
Posted on Jan 20, 2013
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
darjr
  • 378 Answers
SOURCE: Battery?, wiring??
If your Alternator didn't charging the battery, even though you brand new battery will not last. So there is two possible cause, 1) Your Alternator is not functioning. 2) there is a wiring problem that causing your battery to discharge easily, but you check it after you switch off the key remove the battery negative terminal then touch it back to batt term. and see if there is little blue spark, if does your wiring system got problem. If not, so your Alternator do not charge the battery.
SOURCE: the mower shuts down as soon as I engage the
Same thing happened with me, but in this case, the blade shaft was bent and the mower automatically disengaged.
Posted on May 17, 2010
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
SOURCE: my 48 inch riding mower shuts off when I try to
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Posted on Aug 21, 2010
LTX 1042 KW wont start. I was running my mower, had to stop for a moment, now it will not start. It won't even try to turn over
Make sure blade is engaged and you are seated firmly on seat. If so either your blade or seat safety switch is bad. Also your brake pedal bas to be completely engaged.
Aug 03, 2017 | Garden
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
Why does my rover rancher stall when i go to engage the cutting deck
1>the pressure switch under the seat may be malfunctioning? (it will cause the engine to die immediately when trying to engage the cutting blades because it thinks your not sitting in the seat.
2>dirty or clogged air cleaner element will cause engine to die when engaging cutting blades. This can be tested very easily by removing the air cleaner element and then trying to engage the blades again. If this works then replace air cleaner element immediately before running the engine anymore.
I have personally experienced both of these problems myself more that once.
Feb 17, 2015 | Garden
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Replace switches & clutch. When brake is release everything dies. Ineed a wiring diagram.
There are a few safety switches on a riding mower. One is the brake clutch, which must be engaged to start mower if not in neutral for a manual transaxle. Another is a blade engaged safety that will not allow you to start it with the blades engaged and the other is the seat safety that prevents starting if the brake is not engaged.
If the seat safety switch is messed up and you release the brake it will kill the engine. I would start there.
I hope this helps get you going.
Aug 03, 2011 | Garden
My craftsman mower shuts off every time the blades are engaged. What is the problem?
you most likely have a shorted or open safety switch. you did not mention year or model # so I can only guess what configuration you have, but typically there are the following safety switches on a riding lawn mower: clutch/brake on switch (under floorboard at clutch, this allows you to get off the tractor with engine running if brake is applied), Reverse gear safety switch (will shut engine off if attempting to go in reverse with blades on...follow the gear handle rod down to transmission, may be internal or external of differential), there is also usually a disable switch to allow blade operation in Reverse and this is usually relay operated via a button or turn of the key position, Seat safety switch (under seat and usually is disabled via engaging the clutch/brake switch, this switch will kill the motor if you come off of the seat unless brake is applied), and of course a switch that is tied in to tell when blades are engaged (engage handle or PTO switch). It is actually simpler than it sounds and you dont' need to be an electrician to figure it out. start out with a visual inspection of the switches that you can see. I would suspect the transmission position (reverse) switch first, do you have an override? if so, turn it on and see if engine stays running with blades engaged. hope this helps and here is a link to a company that deals mower parts and has alot of great parts breakdown illustrations online. A craftsman is pretty much the same as a MTD or White Outdoor model, so look those up and it will show you the areas where switches are.
http://www.superxpower.com/pages/parts/viewbybrand/55/HusqvarnaPowerEquipment.aspx
Apr 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower runs but blades won't engage.
first check for a blown fuse (owners manual will tell location) next try checking the blade engage switch next check the electric clutch good luck
Sep 10, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Husqvarna Zero Turn Mower RZ4619 Logo
103 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
