Question about Kitchen Ranges
Adjusting RV oven door
I have a 2011 wildcat camper trailer with a suburban stove an the oven door does not close all the way. Looking how to adjust the door
vitg55
  • 70 Answers
SOURCE: adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Posted on Nov 30, 2008
  • 126 Answers
SOURCE: Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Posted on Nov 23, 2007
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
daddy1264
  • 76 Answers
SOURCE: oven door does not close completel. Oven light remains on.
if it closes when you push against it, replace the door hinges
Posted on Jan 01, 2009
fixyourboard
  • 310 Answers
SOURCE: Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at www.fixyourboard.com.
Posted on Jul 23, 2009
Suburban RV oven Door
The springs on the hinges are adjustable. Just move them to a different notch on the attachment points. You have to remove the oven to expose the springs.
Sep 09, 2016 | RVs
SW4P Pilot Water Heater 3 Gallon Trailer Camper RV
These systems use "flame rectification" to sense or prove a flame or pilot flame exists thus it is safe to continue or transition to main burners if a system with a pilot light.
The AC spark is rectified to a DC signal by the flame as the AC current passes through the flame, the flame being a poor conductor only a small amount of DC signal is sent, in the milliamps, so it is not too difficult to interrupt the signal and disrupt the operation, it is doing this for safety.
What you can do is clean the surfaces where the pilot assembly meets the casing and burnish this path clean back to the ignition modules ground or burner ground terminal, there may be a flame sensor too, in this case clean it with 0000 steel wool it is just a ground rod and does not wear out but will build a film that can disrupt the weak DC signal.
Nov 04, 2013 | Suburban SW4P Pilot Water Heater 3 Gallon...
I cannot find the circuit breaker in my 2012 Fun Finder X244 RV. Can you tell me where it is located in my trailer?
I have a Okanagan camper. Mine is below the oven behind a removable panel. It should be close to your AC cable where you plug in.
Jun 16, 2013 | Cruiser RV 2013 Fun Finder X X-244RBS
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
My refrigerator and stove will not run on propane. I have 3/4 tank of propane and my RV is level. Any ideas?
theres a transfer switch that may have went bad.......also (I know you've done this) but check all your valves to make sure there open
Feb 13, 2010 | Safe T Alert Lp Propane Gas Alarm Rv ...
Eurogas oven door
If it is a drop down door, then generally speaking it is the door hinges nthat need replacing, as they are mot usually adjustable.
Hope this helps.
Jan 06, 2010 | Ovens
GE JGSP28 Range broiler problem: flame comes out when door opened
The air shutter should be completely open. A possible adjustment may be necessary towards the closed position. The orifice needle at the orifice hood may be too tight. Take a 1/2 inch open end wrench and turn the hood counterclockwise to reduce pressure on the needle. Do this with the air shutter completely open. Your flame should reduce in size. The best flame would be about 1 inch long with white tips.
Make the adjustments with the flame off. Then light it and check it. If more adjustment is necessary,turn the broiler off before adjusting.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a suburban propane oven in my RV. The stove works great but the oven after being on for 5 to 10 minutes starts to puf out. The flames dies then puffs back on. this happens over and over like it is...
My suburban oven pilot comes on but when I release the oven knob to turn on oven, pilot goes out and doesnt lite oven. I replaced safety valve but still the same problem.
Aug 31, 2009 | Ovens
Kitchen Ranges Logo
895 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
