Question about Transmission & Drivetrain for Honda Accord 4 Door
Auto trans not shifting right
I have adjusted the t.p.s. still not shifting right
    Genius:
  • 1,669 Answers
Try this site:
http://honda-tech.com/showthread.php?t=2925730
http://forums.finalgear.com/questions-and-answers/honda-accord-transmission-problem-help-43774/
Posted on Jan 19, 2013
2001 honda auto trans with to much passing gear
Adjust the trans shift control cable to make it a little longer. Usually located near the throttle area. Two lock nuts hold it in adjustment.
Nov 19, 2013 | Transmission & Drivetrain for Honda Accord
Auto trans dont shift right
check fluid level and see if the fluid smells burnt and fluid is black
Oct 22, 2012 | 1999 Mitsubishi Eclipse
Trans wont go in gear but parg engine runs fine juat wont go in gear
standard shift you need to adjust clutch or replace.check trans oil
auto trans check oils, adjust or rebuild trans. / torque converter.
Apr 02, 2011 | 1992 Pontiac Grand Prix
I have a 1996 f-150 4x4 with a straight 6 auto. The previous owner had the trans rebuilt just before I bought it. Ever since I bought it the fluid looks like new but it shifts really hard from one gear to...
Hi John, Just wanted to throw you a few ideas so you can get a resolution. Sometimes people put in a part called a "shift kit". This has different size openings in the valve body of the Auto trans. It can cause a harder shift and is one possibility.
Next, the Mechanic who overhauled the Auto trans has to put on gauges for pressure readings when finishing the job. The Auto trans is basically a pump (Torque Converter) that pushes fluid under pressure to spin gears. There are different styles of Torque Converters which is a second possibility for your problem. The Mechanics' adjustment of the pressure is a third possibility of your problem.
You need to get the pressure of the Auto trans adjusted. Most of the time it involves using the pressure gauges I mentioned. The newer models of Electronically controlled transmissions can be done by just hooking up a small scanner-computer to adjust the shift. I do not know which type Auto trans you have.
If you are fortunate enough to have the old receipts from his trans job or if the Seller mentioned where he took the Vehicle you are in luck. The repair shop would have a copy of the Work order under the former owners name or the Vin# or owners address. Then you can get a parts list for what was installed inside the trans.
Thanks for using Fixya.
Aug 07, 2010 | 1996 Ford F150 Regular Cab
88 ram 4x4 auto put trans in and it wont shift
Sounds like you got a bad trans. Was it used? Does it have a warranty? Can you shift it with the linkage off? Is everything adjusted correctly?
Jul 29, 2009 | 1988 Dodge Ram Wagon
1997 ODYSSEY AUTO TRANS SHIFTS HARD BETWEEN 1st & 2nd, 2nd & 3rd
It has nothing to do with the transmission, it's your engine mount thats bad.
Jul 27, 2009 | 1997 Honda Odyssey
Harsh shifts after transmission rebuild
they need to adjust the shifting cable, take it back to who built the trans and tell them to adjust the shifting cable, if its not adjusted right, it will burn up the trans again,be sure to get that fixed quickly, also, some trans builders remove the wave plates in trans ,that will cause a hard shift , most likey ,the cable, hope this helps you, thanks robert b.
Jun 26, 2009 | 2005 Chevrolet Equinox
88 toyota supra auto trans slips. won't up shift to 2nd gear
yep, sounds like your transmissions on its last leg, mabye you can get by, by starting in 2nd, if you have the option lol, but auto tran's are pretty cheap on ebay or try www.supraforums.com seen one for 300$
Apr 02, 2009 | 1988 Toyota Supra
Transmission won't shift into 3rd
the trans has a serious failure, that is why the metal, it can be overhauled for less than a replacement
Mar 30, 2009 | 1992 Dodge Dakota
Trans will not shift good on take off drags
Make sure your drag link is adjusted correctly, loosin the bolt and let it kind of slip into it's own position.
This should make it shift correctly, and as an extra measure, put a bottle of lucas trans fix in it....
Nov 21, 2008 | 1996 Chevrolet Blazer
Vehicle Parts & Accessories Logo
134 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Spud Howell
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
