Question about Targus USB Ultra Mini Keypad Keyboard PAUK10U
My number keys arent working because i was hold shift for more than eight seconds the a message popped up then i clicked ok
Try holding down the shift key again for 8 seconds and read the window to cancel the filter keys.
As for your numbers not working, there is a NumLock [number lock] key on your keyboard. Try hitting that and see if your numbers work.
Hope this helps.
shibumi
Posted on Jan 26, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How to delete multiple emails on mac air
    Two options for Deleting multiple mail messages:
    1. The video below shows how to delete a single mail message. To delete multiple mail message you would do the same thing except to delete several mail messages that are in chronological order you would select the top message...press and hold shift....and scroll down to the last message you want to delete and click on that message which will highlight all messages in between the firs and last message you selected. Release the Shift Key. And Delete.
    2. To delete multiple messages that aren't in chronological order click on the first message you want to delete. The press and hold the Option Key (Windows Key if you have 3rd Party Keyboard) and select each message you want to delete and it will highlight all those messages individually. After you select all messages you want to delete let go of the Option Key and click on the Delete icon in the mail menu bar.
    Important:
    This places the deleted emails in your Trash folder within mail. To permanently delete the messages...Right Click on the Trash Icon or hold down Control and then Click on the Trash Icon and select Erase Deleted Items from the drop down menu and they will be permanently deleted and won't take up space on your hard drive.
    Aug 12, 2014 | Apple MacBook Air
    How can i unlock my keyboard
    Recognize that you have a locked keyboard.
    If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
    Use your mouse to move the pointer over the "Start" button.
    Use the left-click button to bring up the "Start" pop-up menu.
    Position the pointer over "Settings" and use the left-click button to select. T
    hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
    Select "Accessibility Options" to bring up another menu, then select "Keyboard."
    You'll see three options that have check boxes.
    Make sure each check box does not have a check mark in it.
    The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
    Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
    If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
    Turn off the computer.
    Disconnect the power supply.
    Remove and then reconnect the keyboard cable, then reconnect the power supply.
    Turn the computer on.
    This will reboot the computer, allowing it to recognize the keyboard.
    hope this helps
    Oct 03, 2012 | eMachines Computers & Internet
    How do I remove icon from my desk top
    There are two ways of doing this I prefer the second way.
    First way:
    Left click on the icon that you no longer want on your desktop and press the delete key on your keyboard. Then click ok, when the confirmation message appears. Now you will have to double click on the Recycle bin and then click file, followed by Empty Recycle Bin.
    The Second way:
    Left click once on the icon that you no longer want and press both the Delete key on your keyboard and the Shift key together. So that's Shift Delete key together. Then click ok when the confirmation message appears.
    This is the shortcut way.
    Take care!
    damnor01
    Nov 01, 2011 | Acer Computers & Internet
    How to unlock my sony keyboard vgp-wkb5fr
    Accidentally locking your Vaio keyboard can cause typed letters and/or numbers to appear on the screen very slowly, or not at all. The locking function can occur if a user holds down the shift key for more than eight seconds. This feature can be unlocked through the computer's Microsoft Accessibility Options.
    1. Click "Start," "Control Panel," "Ease of Access" and "Ease of Access Center."
    2. Click "Make the keyboard easier to use." A new window will appear.
    3. Remove the check-marks next to "Turn on Mouse Keys," "Turn on "Stick Keys" and "Turn on Filter Keys." This unlocks your keyboard.
    4. Click "Apply" to save changes, then "OK" to exit the window.
    if you think i misunderstands your problem or you have any other problem you can post again
    Sep 01, 2011 | Sony VAIO VGP-WKB1 Keyboard
    Who to activate a new iPhone for prepay service please let my now the best way thanks
    if you are using a new iphone, you have to unbrick (activate) it first.
    if you see the apple logo with the usb cable when you turn on the phone, you have to plug your iphone with the usb to the computer, but you have to download the itunes first (www.apple.com) and then click on download itunes. after you have downloaded itunes and connected your iphone thru usb to the computer, follow these steps:
    1. make sure the phone in DFU mode by holding down the power and home button at the same time for about eight seconds, until the screen turns off. Keep holding it down. then release holding the power and home button after 5 seconds
    2. Hold the home button until you see a pop-up in iTunes telling you that your iPhone is in restore mode and must be restored. The popup should appear within 30 seconds after releasing the power button.
    3. Hold the home button until you see a pop-up in iTunes telling you that your iPhone is in restore mode and must be restored. ThIS popup should appear within 30 seconds after releasing the power button.
  • 4. Click OK on the pop-up message and wait for another message that tells you t hat the iPhone is safe to unplug from the computer
  • *** if you unbrick your phone, restoring will erase all data and any apps you had on it before. MAKE SURE to sync and backup your phone in iTunes frequently. You can retrieve information lost during the restore process with the latest backup you did in iTunes
    regarding the prepaid issue, in some countries, there are restrictions that the prepaid sim is not allowed, it is best to contact your service provider if the network allows the use of a prepaid sim card on an iphone
    Apr 18, 2011 | Apple Cell Phones
    How to turn off filter keys on a Eee pc and what
    Filter keys was introduced by the windows operating system its function is to filter out quick repeated keystrokes.
    To toggle filter keys on and off hold the shift button down for eight seconds until you receive a pop up asking if you wish to turn filter keys on/off. In that pop you you will also be given the option to disable the function all together.
    Mar 01, 2011 | ASUS Eee PC 900 Notebook
    2005 cadillac sts remote transmitter
    This is the procedure for a reprogram of the remote's from the factory service manual, if it doesn't work then u may have a receiver issue.
    Use this Procedure for Vehicles with
    Driver Information Center Buttons
    This information is in your Owners Manual in the
    Drivers Information Center Section.
    1. Insert Key and turn to ON position so you can access Driver Information Center
    2. Press the vehicle information button until
    PRESS TO RELEARN REMOTE KEY displays
    3. Press the set/reset button until
    REMOTE KEY LEARNING ACTIVE displays
    4. Press and hold the lock and unlock buttons on the first keyless remote at the same
    time for approximatley 15 seconds. A chime will sound indicating that the remote is
    programmed.
    5. To program additional remotes at this time repeat step 3.
    This vehicle can have a maximum of eight remotes programmed.
    6. To exit programming mode turn key off and remove key.
    Test remote(s).
    Use this Procedure for Vehicles without
    Drivers Information Center Buttons
    To access this display, the vehicle must be in Park (P) with key in the on position (as far
    as you can go without cranking engine)
    1. Press the trip odometer reset stem until RELEARN REMOTE KEY displays.
    2. Press and hold the trip odometer reset stem for three seconds.
    The message REMOTE KEY LEARNING ACTIVE will display
    3. Press and hold the lock and unlock buttons on the first keyless remote at the same
    time for approximately 15 seconds. A chime
    programmed.
    4. To program additional remotes at this time repeat step 3.
    5. To exit programming mode turn key off and remove key.
    Test remote(s).
    Jan 17, 2009 | 2005 Cadillac STS
    My computer crashed, I had it repaired and now I have over 1800 emails. Is there a way I can delete them all at one time?
    if your using outlook express or outlook 2003 then yes
    click on the 1st message until it highlighted in blue hold down the shift key and goto the last message and while still holding down the **** key click the last message. this will cause them all to be highlighted in blue, now just hit the delete and they shold all be gone
    Nov 29, 2008 | Computers & Internet
    My numbers aren't working and my num loc is on
    i got it!! hold down the 2 shift keys for a few seconds then bamm!!
    Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
    Targus USB Ultra Mini Keypad Keyboard PAUK10U Logo
    362 people viewed this question
    Top Targus Computers & Internet Experts
    dhnguyen
    Josh Whitehead
    Josh Whitehead
    Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
