Question about Casio FX-260 Solar Scientific Calculator 1 EA CSOFX260SOLAR
The math problem is x2= 85-84 cos25 and it doesn't work on the fx-260
I have to use the cosine law but i don't know how to work with the calculator to get the correct answer which is 3. Please Help
  • k24674 Jan 22, 2013
    If you take the square root of 8.87015 you get 2.978279705 which you can round up to 3.
  • Casio Master
  • 7,993 Answers
85-84cos(25 deg)=8.87015 and I do not see how you get 3. If angle is in radians the answer is 1.73896. Make sure your calculator is configured to use the right angle unit (radian, degree or gradian).
Posted on Jan 20, 2013
  • 86 Answers
SOURCE: Manual for the casio fx-260 solar fraction calculator
FX-260Solar User Manual
Posted on Feb 09, 2009
  • 7993 Answers
SOURCE: problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Posted on Sep 12, 2009
  • 7993 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
  • 7993 Answers
SOURCE: how to use the cosine,tangent etc functions of
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Posted on Nov 05, 2009
  • 7993 Answers
SOURCE: how do i calculate the pH of a solution on the
General shortcut.
If the concentration is of the form 1* 10^ (-a) where a is an integer between 0 and 14, the pH is given by a.
c= 1.* 10^(-5), pH=5
c=1.*10^(-11(, pH=11.
For other values, ex: c=3.68 *10^(-8)
pH: 3.68 [EXP] [+/-] 8 [LOG] [+/-] Result is 7.434
Above, the [+/-] key is the change sign key, just above the [7] key.
Posted on Mar 16, 2010
On my casio fx-83GT PLUS calculator whenever i use the inverse cos,sine and tan function math ERROR comes up how do i fix this
The inverse cosine function is defined for arguments from -1 to +1. 6 is outside of this domain, thus the error. Do you get an error if you try the inverse cosine of 0.6, for example?
If you're getting the same error for the inverse tangent, could you post an example?
May 12, 2014 | Casio FX83ES Scientific Calculator
Inverse sine function
The sine and cosine function have a range between [-1, 1]. The domain of their inverse functions is [-1,1]. So 20/1 which is 20 is out of the domain of definition of the functions. No limitations for tangent and cotangent.
Oct 22, 2013 | Casio FX-115ES Scientific Calculator
What is the diffrence between the assosiative property and the communitive property in math???
The "Commutative Laws" just mean that you can swap numbers over and still get the same answer when you add, or when you multiply.
The "Associative Laws" mean that it doesn't matter how you group the numbers (ie which you calculate first) when you add, or when you multiply.
Jan 18, 2012 | Health & Beauty
Casio calculator fx115es inverse key not working consistently
The inverse sine is defined only for numbers in the range [-1, +1].
The sine of a number is at most 1.0. There is no number whose sine is 1.5, which is what you're asking for.
The same applies to the cosine and inverse cosine.
Oct 24, 2011 | Casio FX-115ES Scientific Calculator
Cos (A+B)
Gemma,
You won't need a calculator for this. The cosine of 'a' + 'b' is a semi-important math identity:
1. Cos(A+B) = cos(A)*cos(B) - sin(A)*sin(B)
2. Sin(A+B) = sin(A)*cos(B) + sin(B)*cos(A)
Taddahh!
Ofcourse, you could just take the sum of A & B and throw that value into cosines input; but then you would be setting yourself back when it comes time to learn the closely related double-angle identities (which are more important).
Arrivederci,
The Math Cheetah
Mar 08, 2011 | Office Equipment & Supplies
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
I'm just beginning to learn about trigonometric functions (sin, cosine & tangent). My math book says for a problem such as "4 cos 75.8", I should press 4, x, 75.8, cos, = (in that order)....
Try 4 x cos 7 5 . 8 =
The fx-300MS is a more advanced calculator than what the book is describing. It evaluates cosine(x) as cos x rather than x, cos.
Nov 02, 2010 | Casio FX-300MS Calculator
I'm trying to figure out if my Casio fx-260solar calculator can do construction calculations without having to buy a construction master pro calculator if that is possible.
This is a general scientific calculator designed to handle the most common mathematical calculations (at a not too advanced level). It is not designed to handle construction mathematics directly.
However, if you have a collection of construction math formulas and you know how to use the FX260 Solar, I have no doubt that it can handle all your problems. But it will require too much effort in a construction context. Better get a specialized one.
Nov 10, 2009 | Casio FX-260 Calculator
Casio FX-260 Solar Scientific Calculator 1 EA CSOFX260SOLAR Logo
62 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
