Question about Sony KDF-E42A10 42 in. LCD Television
Only red and blue on screen
There's no green in picture
  • carlos_ma404
    carlos_ma404 Jan 25, 2013
    The cable is good. I think is the tv video card.Do you think is better to repair this tv or buy a new one?
  • Sony Master
  • 3,904 Answers
Bad cable, replace it. If the cable is proven to be good then it is bad at the source (cable box) or the tv video card is bad. Eliminate backwards to find out. Plug the tv in with a new cable and if that does not fix it then plug something else into the tv such as a dvd player and see if the problem still exists. If it does then it is the TV itself. Message back if you get that far without results.
Posted on Jan 20, 2013
  • carlos_ma404
    carlos_ma404 Jan 20, 2013
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
Pioneer bdp 51fd picture color is green
check screen options. sometimes you can change the primary color's intensities(it looks stupid at 100% for all). You might have red a little low making yellow and blue show up greenish on the screen.
Oct 28, 2012 | Pioneer Televison & Video
Can i fix my tv screen is red
Toshiba 36A10 36" TV is the model you have indicated---
If the screen is all red and or too bright (no green or blue can be seen) the problem is in one of two places: Either a shorted picture tube or the board that plugs onto the end of the tube.
That board sends red,green, and blue video and information to the picture tube via 3 pins on the tube (the K or cathode for each).
The set will have either 3 IC's on that board or 3 transistors, or a single larger IC for this.
to troubleshoot this:
I would locate the Red Cathode and unsolder that pin at the socket on that board--takes red out---if you have green and blue picture then---it is either the IC/transistor that feeds that on the board or the tube itself.
If it has 3 chips (usually will each have a metal plate attached for cooling) you can either remove and replace the red one OR what I do is swap it with the green or blue chip---if suddenly you now have a blue or green only screen you know that part is bad--simple as that.
If for any reason the picture tube turns out to be bad--you are finished and so is the set= way too expensive to replace it.
Let me know if you have questions or need advice.
Mar 28, 2012 | Toshiba 36A10 36" TV
Picture is black and white, but I have sound. I have red, green and blue plugins. The green one is fine, but I'm not sure which spots to put the red and blue wires in to fix the color.
blue is always in the middle and the green / red are on the ends. Black / white means you have the wrong matching cables. You need to make sure to match red to red, green to green, blue to blue.
Sep 09, 2011 | Sceptre Televison & Video
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Can you post a picture of the Tv with the issue stated?
Feb 28, 2007 | JVC AV-24F703 24" TV
Sony KDF-E42A10 42 in. LCD Television Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
