No Display from new Acer Desktop AX1700
Straight out of the box, connected monitor and everything else. powered up and monitor showed no signal. did try monitor on other computers and it worked fine. tried hooking up monitor several different ways with no results. DVI to VGA, hdmi, and straight VGA and nothing. its like all ports on this thing are dead
  • 1 more comment
  • yourbullit Jan 26, 2009
    All power cables are go, VGA cable is fine. As noted above, monitor was plugged into other computers and worked 100%. Any other suggestions?
  • boch1 Apr 08, 2009
    have same problem no signal to display hdmi or vga acer ax 1700 cables are fine with other computer
  • Anonymous Mar 18, 2014
    check cable but their new
  • 112 Answers
Check all power cable. check vga cable,
Posted on Jan 26, 2009
  • ehsan amin
    ehsan amin Jan 26, 2009
    is it running by agp or pci express card or built in motherboard vga.
    if it is built in mother board vga then i am sorry to say *********** boad is gone.
Monitor states No signal. this is a new computer, just today
Make sure you are connecting the monitor signal lead to the correct signal output on the rear of the machine. Some desktops have extra video out connectors when they have a graphics card fitted. If yours has a graphics card the display connector will be away from the back USB ,audio and keyboard ports and near to some silver pop out panels near the bottom of the tower.
Apr 20, 2013 | Acer Aspire m5640 PC Desktop
Acer d241H display plus mode shows no signal. I want to use the monitor stand alone. When i press the source key to change to display plus mode. the screen shows no signal. (the first time I powered on the...
I had the same issue as yours. After contacting the Acer support team, I got the response as follows. I tired and it worked.
"In order to resolve this issue, you may please perform a power reset. This will remove any static electricity stored in the hardware components that may cause the issue.
- Turn the monitor off and unplug the power cord and VGA cable from the monitor.
- Hold the power button on the unit down for 30 seconds.
- Release the power button and plug only the power cord back into the unit. "
Hope it helped.
Oct 30, 2011 | Acer D241H LCD Monitor
Acer aspire ax1700-u3700a. The dvi port has stopped sending signals to the monitor but the vga port works. I use the vga port but the computer sometimes gives blue screens then strats back woring normally....
I can see you do have two issues here.Let us first fix the DVi port.Please see follow the steps below.
1. Please check video configuration by looking it up on the PC control panel.
2. Please make sure you choose the both DVi and VGA port by simply placing "tick" on the box.
On your second issue.Please follow the steps below
1. The "blue screen" normally comes up if you a faulty VGA cable or the connection is somehow loose.Please check if it is properly plug-in.
2. If the problem continues,I would suggest please contact the manufacturer or the store where the
item was purchase
Sep 04, 2011 | Acer Aspire AX1700-U3793A PC Desktop
My Acer aspire ax1700 PC dsektop wont work and here are the steps I took: First one day it wouldn't power up - The power led would blink once the fan (power supply) would come on for a split second and...
Hi, I had the same inital problem as you, except I didn't put a new video card as I was please with the Onboard card performance that even has an HDMI port. Not sure if your problem is solved already, but in my working process, I first suspected the Power Supply, and I had everything out of the case but the Mother Board. When I tried to fire it up I was always getting "No signal" on the screen, not even a blink from the BIOS. I then put everything back in place, then after the HD started spinning of and Windows booting, the screen started coming on. I felt it was like if I needed Windows to have a clean booth to replace the video drivers and switch to the InBoard card. Hoping this of any help.
Feb 12, 2011 | Acer Aspire AX1700-U3793A PC Desktop
I have an acer AX1700 which boots up but does not give any signal to the monitor.all lights are on from the computer as well as the monitor but the monitor stays black. cables are plugged in...
Before you buy a new graphics card, please try the monitor on another computer. If it's works on another computer, you need to troubleshoot the your machine.
Bring another monitor to your computer and connect it, if it works, then there's no problem with your graphics card. Must be startup or interfaces problem.
(Note: do all the connections before you power on the computer and leave your monitor On before your switch on the computer.)
If another computer works on your computer, then replace with a new display cable (vga/hdmi/dvi which suits your monitor).
Do let me know after you are done all these.
Good luck.
Thanks for using FixYa.
Jun 30, 2010 | Acer Aspire AX1700-U3793A PC Desktop
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
I work with 2x193W LCD Monitors together. One is working fine, the other is now giving me the "No signal" screen. I have checked connections and pins. Everything seems alright. What am I missing?
Open you video cards control panel and check the display settings. Check to see if it is set to duel view or single display. You can also open your display settings for your computer. Under the settings tab choose which monitor is showing no signal and make sure it has a check mark on the box that says extend my windows desktop onto this monitor.
Jun 08, 2009 | Acer X193W LCD Monitor
Acer Model AL1916W A reads no signal after being on for 1 hr
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
"no signal " on the screen
After half a day of tinkering around with my new Acer I fixed my problem, which I think is yours also. I connected it to my notebook, it read the signal 'D-Sub' or something like that, and after my notebook finished startup, it reverted to no signal. I tried it with my desktop and it worked just fine. The display will only show up on one output device. It worked fine on my desktop because I was unplugging my monitor in order to hook up the projector. Hooking the projector up to my notebook left the display panel still active and that was where it displayed. In case I'm not making sense, the solution is this: After setting everything up, hit Control+Alt+F1 to switch display from your screen to the projector. To switch back, hit Control+Alt+F3
Oct 15, 2008 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Computers & Internet Logo
352 people viewed this question
David Payne
David Payne
