Question about Husqvarna 7021 21Inch 160cc Honda GCV Gas Powered Lawn Mower ()
Just bought this mower honda hush arena 21 " push mower and it throws clippings all over the deck, why? Looks like its coming from the side outlet
  • 755 Answers
See if the side outlet needs a plug underneath to keep the grass inside the deck to be mulched. A lot of mowers have these plugs but this one might have not been installed.
Posted on Jan 26, 2013
Where is the oil drain plug?
Usually the drain plug is located under the deck by the shaft. It looks like a inverse plug. Use a socket wrench to undo it.
Apr 23, 2013 | Ariens 21 In Classic Walk Behind Push Lawn...
Yard machine 21" 6.5 does not catch all clipping when bagging dry grass. Under deck is clean and the deck height is even. Also leaves blades of grass uncut. The mover is brand new and the blade is very...
Did you buy this mower from a dealer and built up and checked over or did you buy it in a box and put it together yourself? i suspect you probably bought it in a box and put it together yourself as it sounds as though the engine isnt reving high enough. Briggs and stratton engines are well known to come out of the box with the engines reving much lower than they should be. you will need to check and adjust the high speed engine revs to approx 2900-3100 rpm
Aug 18, 2010 | Mtd 22" Yard Machine Push Mower
Left side blade cuts about an inch lower than right side , the left 21" when cutting is about an inch lower than the right 21", looks terrible, checked tire pressure and that was not the problem
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
Jun 14, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How to adjust mower deck height
There should be two threaded rods with a nut on them that goes from the frame to the deck. Check the height of each blade and which ever side is out of balance you can disconnect that sides rod (usually held onto the mount with a clip or cotter pin) and turn the rod to either raise or lower your deck until it is level.
The above was for leveling your deck.
If you just need to raise or lower the deck depends on if you have a lever on the right side with a push button on top just depress the push button and push forward to lower or pull back to raise.
It might have a round knob that you turn to raise or lower.
Good luck
Sep 03, 2009 | Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Craftmen mower doesn't cut well on right side
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
Jun 28, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Uneven cutting height
Hi Matt,
Thanks for the update. Good ole brainstormin' comes through again!
Charlie
May 07, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Husqvarna 7021 21Inch 160cc Honda GCV Gas Powered Lawn Mower () Logo
104 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
