Question about Ovens
ELECTROLUX OVEN WONT REACH TEMPERATURE
OVEN STOPPED WORKING DOUBLE ELEMENT INNER ONE ONLY WORKING FAN WORKING
    Top Expert:
  • 9,472 Answers
What is the model number of your unit?
Posted on Jan 19, 2013
  • 1 more comment
  • COLIN PARR Jan 20, 2013
    Hi Richard it is a uk model and the number is EOB 966
    electroluxx eob966
  • Richard Roth
    Richard Roth Jan 20, 2013
    Sorry, I don't have any info on that UK model.
SOURCE: Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Posted on May 15, 2008
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
  • 291 Answers
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Posted on Aug 31, 2009
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Dec 06, 2007 | Electrolux EOB6632 Electric Single Oven
My electrolux EOD5330 fan oven tripped a fuse. ow it won't heat. The fan still works
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
Feb 10, 2011 | Electrolux EOD5330 Ultrafan Electric...
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
Nov 09, 2010 | AEG U3100-4 Electric Double Oven
Replaced fan oven element but now now fan and no light
remember to set the time of day on the clock it wont work until you do.if you have done that then it could be clock relay contacts that are faulty.
May 20, 2010 | Electrolux EOD5330 Ultrafan Electric...
Heard a pop/bang and now no heat
Sounds like the oven element has blown.
To fit a new one, remove cover at rear of inner oven compartment, there you will see the round fan element.
Apr 06, 2010 | Electrolux EOD5330 Ultrafan Electric...
My oven's fan works, but the temperature is not on? PLease help???
the main element is heater must be checked 1st by ohmmeter then to assure the suitable voltage reach at suitable time by control or not this also can be checked by voltmeter>
then check wiring if voltage not reach.
so determine the dead element and replace it also do not forget the bad contacts
thanks
Jul 11, 2009 | Electrolux Ovens
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
