Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice keeps building up on coils
I have a side by side GE model GSS22WGMB. Ice keeps building up on the coils behind the aluminum wall in the freezer. I have unplugged the refrigerator, removed the aluminum cover concealing the coils, let the ice melt. clean the fridge and plug it back in. After three weeks or so the ice builds up once again and I go through the same process. What can I do to rid this problem? Any information will be greatly appreciated.
  • bonislo Mar 08, 2009
    Ice keeps building up on the coils in the freezer of my side the side. I thaw it out and one to two weeks later its frozen up again. This is a fairly new fridge ad it mkes no sense.
  • wishitworked Mar 10, 2009
    Same problem from almost the time it was delivered. Ice builds up on the coils and then everything stops being cold. Melted ice cream etc. Even the chill (not freeze) side isn't cold anymore. I have resorted to removing the back panel and defrosting the iced over coilds with hot water every SAT. am. I cannot afford the repairs since the local shop said it was $120.00 just to come out (trip fee) and then MORE MONEY to diagnose and repair. Are they kidding? GE SHOULD NTO SELL FAULTY REFRIGERATORS. I'm STUCK WITH IT.
We had the same problem with our GE frig, a Profile 24. When the tech came out, he explained that the energy efficient models have only 1 defrost heater, but the older units had 2 and the hook up and mounting positions were still there. As long as I directed him to install the 2nd heater he could do it. It turned out the original heater was just fine, so the replacement was installed in the 2nd heater space and it has worked fine for several years now. Before doing this on yours, I would verify that the defrost timer is working and the heater unit is ok.
Posted on Jan 26, 2009
Defrost ge regrigerator
The most common problem with the defrost system is a burned out defrost heater. It is located behind the frz back wall usually attached at the bottom of the aluminum cooling coils which will probably be full of ice and frost buildup. You will need to melt all the ice off the coils with something like a hair dryer. The heater is inside a glass tube and can be tested with a multimeter or sometimes you can see the break in it through the glass. In some cases there are 2 or 3 heaters at different levels. Replacement kits should include as many as needed for your model. Replace them all. 2 other parts to the defrost system are the defrost timer (usually located on the front channel under the freezer door) or the termination thermostat which is a silver disk clipped to the top of the aluminum cooling coils with 2 wires going to it. Any of those 3 parts could cause the frost buildup but the heater is the most common.
Apr 05, 2015 | GE Refrigerators
We have replaced our G.E. side by side refrigerator mother board ,it did fix the problem with the ice maker and water not working ,a week later ,the ice started to build up agian and fridge is not getting...
The bdefrost heater behind the wall inside the freezer is bad if the ice you have is on the back wall of the freezer. Remove the back wall and deice the coils and replace heater. wr51x10101
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cool enough even on higher settings
I posted this on another problem, but this may help you too.
Check to see if there is frost on the back panel of the freezer.
If there is try solution below:
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE GSS20IEP Side by Side Refrigerator
Fridge autodefrosting but condensation not draining away and evaporating causing a build up of water in bottom of fridge section
The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campion
Feb 27, 2009 | Miele KFN8762SDED Bottom Freezer...
Refergirator not cooling
Defrost system failure.
Defrost system: Freezer fan, Defrost timer, Heater, Thermostat. If any one of these are bad the coils in the freezer will get clogged with ice and not allow the cold air to circulate over to the ref. side.
Ice/frost build up on the back wall of the freezer is an indication of this problem. You can manually defrost with a hair dryer which will give you a couple of days before it starts iceing up again. Remember, the ice you see on the back wall is just the tip of the iceburg, there is a lot more on the coils behind that wall.
Jan 06, 2009 | Amana ARS2464B Side by Side Refrigerator
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
291 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
