Question about Garden
I have a easy kleen pressure washer 4000 i need the wiring diagram for the electric starter
2 Suggested Answers
LandaNW
  • 45 Answers
SOURCE: Need wiring diagram for the burner on. a Landa
If you can provide the full model and serial from the model tag on the machine I would be happy to send you a wiring diagram. The model tag is normally located on either the frame of the equipment or on the side of the electrical panel. Depending you your model it should look something like the following.
Model: PGHW5-35324ESerial: P0108-890345
We are the original Landa factory in Portland, Oregon and have digital copies of user manuals, breakdowns and wiring diagrams for every machine that Landa has ever produced. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, Inc.aron.kerr@landanw.comwww.landanw.com800.247.8103
Posted on Apr 18, 2012
Wiring diagram for replacement motor
Here is a pdf file maybe this will help.
The power cord has three wires there should be a green =ground black hot white neutral.
http://www.greenworkstools.com/uploads/documents/51012_1700PSI_Pressure_Washer_E_Manual.pdf
May 15, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Had to replace new pressure switch on a karcher k6.50 pressure washer ,but I forgot which wire goes to which terminals.
if its two wire it shouldnt matter... if it's multi wire then you are going to need a proper wiring diagram from them
Oct 13, 2013 | Electric 1600 Psi Pressure Washer
I need help wiring in a new speed control on my bosch table saw 4000. The new speed control came with a large black wire, a small black wire and a small blue wire. The large black wire was easy and I...
ts4000 Bosch motor wiring (post #210578, reply #6 of 7)
by emils01 in reply to emils01 [original] on Tue, 09/30/2014 - 15:50
So I called Bosch on Monday and they were well informed and helpful. They emailed me a schematic and explanation of ...
4000 PCB wiring diagram.
1. White AC line cord to white field wire.
2. Black AC line cord to thin blue wire on PCB.
3. Black motor field wire to thin black wire on PCB.
4. Black long, thick wire on PCB to red motor brush wire with push on connector.
Sep 18, 2017 | Bosch 4000 - 07 Electric Table Saws
How do i connect he differenial pressure switch into the 3ph star/delta starter circuit?
Your question is a bit unclear, but I assume you are asking how to wire the pressure switch in a piston compressor.
See the diagram, below.
You should have a wire from the L1 (first incoming main voltage) terminal to the pressure switch, and from the other pressure switch terminal back to the starter coil. You will also have a wire from L2 (second main voltage terminal) to the overload, and from the other overload terminal to the other side of the coil. In this arrangement, the motor starter coil must be rated at the SAME VOLTAGE as your incoming power.
This diagram works the same for single phase machines (they just don't have the third wire coming from the supply through the starter and overload to the motor.
If your machine has other safety controls (like a low oil switch), It can be wired in series with either the pressure switch or the overload.
Nov 03, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
How do i connect the differential switch into the 3ph star/delta starter circuit?
Nov 03, 2009 | Ingersoll Rand Ingersoll-Rand Air...
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
Electric or Gas?
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Aug 27, 2008 | Briggs & Stratton Power Products 1539...
Honda atv wiring
you need a starter box w/c includes push swtich , install near the handle put attachement to bolt , wiring to starter red in color to box terminal, black wire connect to box terminal direct battery , install fuse depend to the starter amphere , series to black line positive + .connect green wire to the negative -- from battery to body of the strater or ground bolt. then start it. Thanks
Dec 29, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
484 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
