Kenmore he2 front load washer
Leaks all over the floor in the rinse cycle
  • 1 more comment
  • smithereen12 Mar 16, 2009
    kenmore he2 front load washer leaks on the floor in rinse cycle
    help?
  • HE troubles Mar 21, 2009
    Washer leaking from the bottom, opened lower panel and it is leaking below the door seal, checked the rubber seal all around form the inside for damage and could not find any. Has anyone had a door seal problem?
  • Anonymous May 06, 2009
    yes had seal(boot) problem very easily damaged by zippers-bad design costly to repair unless you do it yourself.should be recall because the HE T3 are doing it also
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
How do I balance a Kenmore HE2 Front Load Washer.
You need to level the washer. They also have things to put under the feet to keep it from moving. Or try to block the feet.
Jul 05, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus stops during wash cycle
What is the maximum capacity (laundry weight load) of your washer? And how much weight do you consider a large load, that you are placing in the washer?
Dec 31, 2013 | Kenmore HE2 Plus Front Load Washer
Front load kenmore will not spin at end of wash
I have to know a little more detail before I can give you a reasonable solution. Does the washer drum fail to spin period? In other words, if you select rinse cycle manually, after the rinse cycle completes, does it fail to spin? Also, please give me the model number so I can look it up on my tech site. Thx Rick
Oct 06, 2011 | Kenmore HE2 Plus Front Load Washer
My washer does not seem to be going through the rinse cycle.It doesnt drain all wash water out. When it FINALLY stops the letters Sd are lit............WHY
overdose of detergent during wash cycle try running the unit in a rinse spin here is also a tehnical sheet that u can get from this site as a pdf sd stands or suds lock http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
hope this helps
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Does anyone know the code to make a HE2 Plus "spin only"?
select the Spin/Drain cycle. any special code would have been the service/diagnostic mode but that wants to run a factory test which involves water fill and agitate
Apr 28, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
