Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Insignia TV ... big RED X on Screen!
I have an Insignia TV, I have AT& T Uverse... I unplugged everything moved it around... plugged it all back in.. yes, I know for a fact it is plugged in properly. I was having major issues with AT&T Uverse, and now all TV's are back working properly with the exception of the Insignia. I have gone thru the settings, and all I get is a big red X on the screen after allowing it to run thru whatever set up process it was in... any suggestions??
This just happened to me this evening and I have an Insignia as well.
With your TV on, try unplugging and repluggning in your HDMI cable. Hold your reboot button for at least 15 seconds. Should reboot and work.
Posted on Feb 08, 2009
Direct Tv mini caused my Insignia tv to freeze and now tv wont turn back on
The direct mini did not freeze the tv. It's a coincidence. Your TV needs repair. Unfortunately insignia tvs have a reputation for problems like this.
Aug 13, 2016 | Insignia Televison & Video
Only getting red light
Is this when the TV is on or off? If it occurs while the TV is on, is it constant or intermittent?
Try this: Unplug the TV. Hold down the power button on the TV for 30 seconds, while the TV is still unplugged. Then plug in the TV and turn it back on.
Similarly, power cycle the TV: turn it off, unplug it and leave unplugged for a couple minutes. Plug it back in and power it on. Reset settings back to factory defaults. If all else fails, I would recommend pursuing repair/replacement options.
Nov 07, 2013 | Insignia NS-LDVD19Q-10A LCD TV
I can find codes for a black standard uverse remote which is 1040. But I cant find a code for silver standard uverse remote. Uverse says to talk to DYNEX. Can you help?
i currently use uverse and none of there remotes work for dynex tv's i suggest buying the logitec harmony 520 or 420 or above remote from amazon read the reviews there around 40 dollars and lets you control everything and they connect to you pc you just plug in you model number and the remote learns all the commands as well as lets you set up activities that will allow you to control multiple devices without having to switch between hitting the tv button, home theater button, uverse box etc.
hope this helps.
Mar 14, 2011 | Televison & Video
Blue red green lines around people images
this is caused by some kind of electrical interference. this can be caused by cd players,speakers, etc being too close to the tube. after you find the culprit and remove or move, unplug tv for about 10 mins, then plug back in
Sep 06, 2009 | RCA F32649 32" TV
Insignia LCD TV 26" Colored Streaks/No Picture
You have a bad LCD panel. The cost of a repair would exceed the value of the unit. Panel will probably cost, if you could find one, around $300-$800.
Jan 02, 2009 | Insignia LCDTV26 26 in. Television
Unplugged insignia box replugged cannot access menu unit comes on
Plug the Insignia output to TV video 1. Turn on TV, set to video 1 source. Turn on Insigna. You should now have picture and be able to go through the set up again.
Dec 31, 2008 | Insignia Digital-to-Analog Converter for...
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
2,864 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
