Question about Rheem RUUD ELD40 Water Heater,electric,40 Gal,208v,4.5kw 3CFG6
How to wire a rheem 40 gal electric hotwater heater with a yellow,blue, and Black wires
  • Rheem Master
  • 5,089 Answers
Jan 2013
1) Water heaters can be wired many different ways.
Copy following link For ordinary household 240Volt water heater, the heater is wired for non-simultaneous operation:
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
Copy following link For other wiring diagrams, including off-peak, simultaneous, redundant, etc
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
2) Make sure water heater circuit breaker and wire size matches watt rating that shows on end of each element.
http://waterheatertimer.org/Color-codewire.html
3) Non simultaneous means only 1 element is ON at a time.
So either upper element is ON, or lower element is ON, or both elements are OFF.
Both elements are never ON at same time.
So non-simultaneous water heater with two 4500 watt elements has total connected watt rating of 4500 watts. Because only 1 element can be ON at a time.
Use 30 amp breaker and 10 gauge wire.
Posted on Jan 20, 2013
3 Suggested Answers
  • 40 Answers
SOURCE: 40 gallon rheem electric hotwaterheater, amps to
ha ha ah
Posted on Oct 30, 2009
  • 122 Answers
SOURCE: installed new rheem 40 gal
did you turn the power on BEFORE you filled it with water???
this is a pretty common mistake. you will need to check the upper element to make sure its working.
most water heaters have an upper and lower themostat. the upper thermostat is the one we need to check.
use your volt meter...
turn the power off, test with your volt meter to make sure! remove one wire from the element, not the thermostat, and check resistance on the element. if no resistance, you burned the element, and will need to replace it.
replace with same wattage, usually 4500watts. it will be written on the element.
also, I like to push the reset button on the thermostat to make sure it wasn't tripped.
Posted on Aug 31, 2010
Elctrical wiring of the thermostat Rheem hot water system
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Do I need to use the heat trap nipples on my new Rheem electric hotwater heater, I am pressed for space Thanks
Rheem residential electric water heaters appear on following page:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
New water heaters are made with heat trap nipples pre-installed so the product meets industry energy standards.
Sample Rheem manual says: 'All models equipped with heat traps.'
http://globalimageserver.com/fetchDocument.aspx?id=052c9e32-ce37-48d7-8990-9e430f23fef3
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Rheem 38 GAL ELEC SHORT Water Heater 6YR...
Wiring an electric water heater
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Apr 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My hot water heater has a red and a black wire,but the electric supply wires coming in to power the water heater have a red,black white and a bare ground. Which wires go where?
Your 220v hot water heater does not need the neutral(white) wire coming in. Bare wire goes to ground -green headed screw. Black goes to black, Red goes to red. White gets teminated with a wirenut or some electrical tape.
Jan 24, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
I have a probally ancient hotwater heater rheem
You will find two covers on the front.Behind each cover the you will find a thermostat ,there will be adail on it. It might be numbers like 120,150 or it might be letters,like A,B,C and so on.You take screw driver and turn to the right until you get the tempture you want.
Mar 23, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem RUUD ELD40 Water Heater,electric,40 Gal,208v,4.5kw 3CFG6 Logo
148 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
