Question about HP Pavilion dv9000z Notebook
Anyone had hinge or structural issues (cracks in the thin trim) with the Pavilion dv7? Returned one to Sam's since it was within 3 month warranty. Four months later, the second one cracked the
It cracked on both thin trip pieces above the air vents on front. I have been loyal to HP but I do not think that will continue.
    New Friend:
  • 11 Answers
I have the same problem when I sent it to HP they put it back together with black tape. Cosmetically it looks horrible but it has been working fine for over a year.
Posted on Jan 25, 2013
    New Friend:
  • 14 Answers
Hi
this is normal the way how hp do things
if you have cosmetic damage if the bolts been ripped offand you have little budget order the hinges from ebay strip down the plastic take out the screen reseat the bolts push them down litle bit with soldering iron and put around them epoxy glue just little not to much max 3 mil around the bolts.the resin glue is in pound shop you have to mix it 1 to 1 seting time depend on arwentilation and room temperature but is about 4 to 5 min.
hinge always need to be replaced because is from dural simmilar to aluminium and stinless steel usuallu one material r soft another hard so because in the factory you they put grease all alu dast stick into grease and after time become tight thats why the hinge brake.
some hinges has washes and nuts and bolts you can release them usually in the factory they finishig the con on the end but with player you can ower turn this.
i hope this help
Posted on Mar 15, 2013
  • 144 Answers
SOURCE: Cracked touch screen Hp Pavilion tx1020
try ebay
if you get a screen go to http://repair4laptop.org/disassembly_acer.html to find out how to put it in
Posted on Dec 01, 2008
  • 8 Answers
SOURCE: Broken (cracked) right Hinge on HP nc 4000 and Dell D600 Laptops
You can get replacement parts for this laptop, however it can get expensive. At the end of the day, you can use a super glue that is safe to use around electrical parts, but you might be better off just using an external monitor if you don't need to carry your laptop around.
Posted on Jun 01, 2009
T-Mania
  • 42 Answers
SOURCE: printer port for my new hp pavilion dv7?
You should be able to use a parallel to usb converter heres one in the link. There hard to find most are usb to parallel but this should work.
http://www.usbtech.com.au/product.php?productID=GW-K200
Posted on Mar 23, 2009
rulds2008
  • 3866 Answers
SOURCE: how to put hp pavilion dv7-1245dx key back on the
They just snap back on but notice if the key is broken then what you need to do at this point is by a replacment key or buy a replcement keyboard.
Posted on Jul 31, 2009
SOURCE: hp dv7 keyboard issue
Hey guys, I just had this problem, I have alot of problems with my DV7 laptop, top panel started malfunctioning, then it thought i was turning the volume up and down by myself, also my g h ' and backspace stopped working along with other problems that I don't want to bore you guys with, whats the answer? Remove the battery for 10-15 seconds and clean the connectors and this has ALWAYS fixed all my problems. Hope this helps.
Posted on Jan 26, 2010
Loose hinges how do I tighten them
Watch the video it shows which screw hold the hinges to computer itself and to the screens back cover. HP DV7 LCD Screen Replacement
Mar 09, 2015 | HP Pavilion dv7-1130us laptop
Imam hp pavilion dv 7 laptop i u njemu ugradenu kameru hp webcam ali ju nemogu ukljuciti
Sve u svemu, izgleda mi da treba da instaliras nove drajvere. Nasao sam ove sajtove, ali molim te prvo proveri koja verzija windowsa imas (32 bitna ili 64bitna) Mozes da proveris za desni klik na iconu My Computera i selektiranjem Properties. Trazi nesto gde pise 32bit operating system ili 64 bit operating sistem. Ondak skini nove drajvere sa ove linkove
32 bitan - http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-75835-1&lc=en&dlc=fi&cc=fi&lang=fi&os=4062&product=3939026
64 bitan - http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-75835-1&lc=en&dlc=fi&cc=fi&lang=fi&os=4063&product=3939026
skini odgovarajuche i sa srecom :)
Oct 22, 2012 | HP Pavilion dv7-1137us Notebook
Screen loose connection
Check out these WEB sites for instructions.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/ b>
Oct 20, 2012 | HP Pavilion dv7-1130us laptop
HP DV7 laptop hinge has malfunctioned
try these guys at http://www.generalsystemsconsulting.com
They can repair it if you can't do it yourself. They are also reasonably priced.
Mar 10, 2012 | HEWLETT-PACKARD Pavilion DV74065dx...
HP Laptop was running poorly for a while. Wouldn't connect properly and fan running on high. Got pissed off after 12 hrs of trying to connect and threw it on the floor. Now I can hear the fan, and the NUM...
Throwing the computer on the floor could have caused some of the connections within to come loose. It could have also cracked the LCD screen. Unless you're willing to disassemble the laptop and painstakingly go through checking all the connector cables and structural integrity of the circuit boards, I'd take it to a shop and have them look at it. Hopefully it isn't damaged permanently...
Good luck.
Mar 11, 2011 | HP Pavilion dv7-1130us Notebook
Is the price of HP Pavilion dv7 battery for hp
That's expensive.
Try http://www.bestezonlinestore.com/home.php?cat=10002063
Quite cheap batteries.
Jan 28, 2010 | HP Pavilion dv6000z Notebook
I managed to crack the LCD on my hp dv7 laptop. What is the easiest way to get the screen out to replace it?
Typically there are two screws on each hinge that is mounted inside the back of the laptop. You'll have to get the top indicator panel off to get to the connector(s) coming from the LCD. The usual process is unclip the wiring harneses and then remove the screws, and the screen and hinges come out. Replacement is the reverse.
Some laptops you have to remove the entire top of the laptop (keyboard/touchpad first, then the cover assembly. Others you can just pop the rear button cover (usually where the LED indicators and power button are located) and access the LCD connectors there. Best way is to go to HP and find the service manual information which will tell you how to remove that specific piece of hardware.
Jan 01, 2010 | HP Pavilion DV7-1020US Laptop
My computer wont open
Hi woc169! Your problem may be related to an HP recall/repair announcement regarding left side hinge defects. Go to http://www.hp.com/#Support or call the number at the end of this message. Hope this helps!
HP Limited Service Enhancement for Left Display Hinge
HP has identified a hardware issue with certain HP Pavilion dv9000, dv9100, dv9200 and dv9400 series notebook PCs.
Step 3: Identify the symptoms Ifyour computer’s product number is listed above, and the notebook PCexperiences one or more of the symptoms listed below, contact HP duringthe Duration of the HP Limited Service Enhancement to determine whetheryou are eligible for a free repair. Symptoms of a broken left display hinge include but may not be limited to the following:
  • Whenopening or closing the display panel, you may hear popping or cracklingsounds from the bottom left corner of the display (left hinge area).
  • When opening or closing the display, the display may feel loose or wobble in the lower left corner.
  • The plastics surrounding the left display hinge may show cracks or breaks.
Service enhancements and free shipping
NOTE: This HP Limited Service Enhancement program is available in the United States and Canada through May 31, 2009.
  • Free shipping Ifyour notebook needs to be returned to HP for repair, the shipping costsare free. HP will immediately send you a postage paid container inwhich to send in your computer, and we will pay the return shipping. AfterHP receives your notebook PC, HP will use its best efforts to repairand ship your notebook to you within 10 to 14 business days.
  • Post-service warranty The HP repair warranty covers the left hinge repair for 90 days after HP returns your notebook PC.
Contacting HP To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
