Question about GPS
My Garmin Frontrunner 610 locked up.
While transferring data, my running watch locked up when i walked out of range. I cannot turn it off or reset it. Help of any kind is appreciated. Thanks
5 Suggested Answers
  • 84 Answers
SOURCE: Garmin forerunner 305 won't come on.
My wife's was always powering off during runs. Then it would not power on at all. There was a connection inside that wasn't making contact. But first First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some brass fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps.Here is a link I found on opening a 205 (Same process)http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker.Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs more that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag.Let the unit sit over night. In the morning remove the tape.
Posted on Jun 09, 2009
SOURCE: MY Garmin 405 wont download
I got the same issue and it was because of a software update to ANT+ agent being not compatible with the 405.
here is what I got from Garmin Support.
This solved my problem:
There is currently an issue that has been identified with the latest
version of the ANT agent where it will not transfer data to the computer
from a 405cx. To resolve this please follow these steps
1. If the device has paired it will need to be removed. Right Click on
the ANT agent, select Device Settings then click Remove Device.
2. Right Click the ANT agent and select Exit to close the ANT agent
3. Go to the Control Panel, select Add / Remove Programs and uninstall
the ANT agent.
4. Reboot the computer
5. Download the previous version of the ANT agent from http://www8.garmin.com/software/GarminANTAgent_221.exe
Run this file once it has downloaded
7. Turn on the pairing on the watch ? to do this go to Menu > Settings
> ANT+ > Computer > Pairing (on).
8. Enable pairing on the computer - right click on the ANT agent icon
and select Pair With New Devices > Enabled (this may already be enabled)
The Forerunner and computer should now pair, please be aware that it can
take several minutes for the computer to find the watch.
Posted on Jul 21, 2009
  • 20 Answers
SOURCE: Garmin nuvi 610
https://buy.garmin.com/shop/buymaps.do
Garmin offer new maps, the majority in different formats such as online downloads, pre-loaded SD cards, or on DVD.
However, these are pretty costly for all they are worth. For the same price as a map, you could easily buy a brand new device with full EU maps.
Posted on Dec 11, 2009
SOURCE: Transfer "favorites" from Garmin Nuvi 660 to 765T
I had the same problem. I called Garmin and the lady said if I had the software Map Source or something, that can do the trick, but the funny thing is you have to buy the software with Map Updates, or you get the software when you buy a new unit, and register the unit within 60 days of first satellite reception. Though I searched internet and someone said to copy a certain file/folder or I'd rather just copy the whole GPS folders and that might do the trick. You are right, this is a pain in the rear end.
Posted on Jan 13, 2010
Activating my new phone/im locked out / stuck at setup with google account t
In order to overcome the forgotten passcode you must do a factory reset, it will wipe the phone clean and you will need to input all the data again.
Jan 06, 2017 | LG Cell Phones
My daughter locked her tablet by using the wrong pattern 1 to many times.. Can you please advise how to reset the tablet.I have no Network Connection as the Wi Fi has been turned off.
You are going to have to hard reset your tablet. Typically, if you long press the volume up and power button at the same time. Without getting into details, visit Youtube and there are videos that walk you through the hard reset. Here is one that might help: https://www.youtube.com/watch?v=eJXFAdh7UJg
Sep 29, 2015 | Tablets & eReaders
Reset time on bench watch bc0013br
I have a Bench Watch BC0013BR and do not know how to set it up any help would be appreciated
Oct 05, 2009 | Watches
Upper oven locked and cannot unlock. It operates but...
Have you tried cutting the breaker to reset it ? This will sometimes work on electronic equipment to reset factory default settings.
Jul 25, 2009 | Kitchen Ranges
1991 Range Rover AWD Doesn't Work
im sure you checked this but they have a habbit of snapping front prop, i would guess this has happend and been removed. the transfer box is a borg and worner, on a p36 i have never had or heard of trouble, ive been inside p38 transfers and there is nothing to prevent 50 50 split power. the axle its the same. check the prop is still there, if so get back to me.
Jun 24, 2009 | 1991 Land Rover Range Rover
Alarm Lock Trillogy DL2800 and DL Windows Program.
If you can load DL windows onto a laptop instead of a PC, you can program directly to each lock using a AL-PC12 cable which connects from a 9-pin serial com port on your computer, to the 2-pin banana plug on the lock.(be sure to observe polarity). Cable is available from Alarm Lock. Some very useful downloads and information is available on their website - www.alarmlock.com
I hope this helps!
Apr 24, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
MY Garmin 405 wont download data. It make the connection and gets to the tarnsfer point then "transfer failed. I've one route downloaded last week but none since. I tried: resetting both...
the ANT agent.
May 14, 2008 | GPS
SECURE FILE TRANSFER
With?
What are transferring from computer to computer?
Please describe more..
Thanks,
Cam
Oct 19, 2007 | Computers & Internet
NO file transfers are working!
Try deleting the partnership in ActiveSync on the PC, and then create a new partnership. I saw this problem, when I connected the first time to a PC. I tried connecting to a second PC, and had no problem. When I went back to the first, it required that I create a new partnership, and no problem with the connection.
Sep 14, 2005 | Dell Axim X5 Pocket PC
GPS Logo
153 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
