Question about Culligan Under Sink Water Filter
Slow culligan drinking fauset - Culligan Under Sink Water Filter
    Top Expert:
  • Culligan Master
  • 50,533 Answers
Check the micro setting of the cartridge and if it is ceramic or not. If ceramic and it is dirty and slimy then all you need is the back of a knife and scrape it back until the ceramic is clean. If it is carbon it may be blocked and will need replacing with a new one.
Posted on Aug 03, 2013
How much time does culligan man need to install drinking water system under sink
Time = degree of difficulty from the lack of space
it also = the amount of pipe preparation needed to fit the system
so a reasonable amount of time would be 1 hour minimum to a max of 4 hours after which the person would be playing on your patience
always get WRITTEN quotes first from several installers and accept the average
Sep 18, 2017 | Culligan Tools & Hardware - Others
Trying to connect Culligan drinking water filter to my faucet, BUT, the treads on the faucet are too high for adapters to reach. How can I connect? Also adapters aren't long enough to reach threads....
One thing to try is pick up a tap adapter, from an appliance store. The adapter is intended to connect a portable dishwasher or washing machine....these adapters have several small pieces that may be able to be used with the pieces from the Culligan adapter.
May 01, 2011 | Culligan Home
Leaks on the top of black box of culligan water softner under sink system
Is this a reverse osmosis drinking water system? If it is it is an H8 RO. If so shut the water off that feeds the RO. The leak is probably coming from one of the fittings, they can be cut by the compression fittings and leak.
RJ
Feb 13, 2011 | Culligan Under Sink Water Filter
My system vibrates & resonates loudly when the ordinary tap is switched on. Also, water comes out of the filter tap when it isn't turned on, sometimes in a stream, other times constantly dripping. Have...
You are getting water feeding back to the kitchen faucet from the filter system. A check valve needs to be installed on the line feeding the drinking water system to prevent this. Excess pressure may also be causing these problems. An in-line flow restrictor may alleviate the dripping.
RJ
Oct 27, 2010 | Culligan Under Sink Water Filter
Two years ago I changed the size of my Culligan holding tank under the sink to a bigger unit and at the same time put in a culligan water softener that also removes chlorine. I also changed the culligan...
hi.
im a plumber and i have seen it meny times befor. relax its calk thats in the water, its harmless and most gps wil tell u iets good for you lol
if it dos freak u out u may wane install a finer vilter sustem
Jul 07, 2010 | Culligan Sales #SY-750S Under Sink Water...
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
Dishwasher is leaving white film on dishes. I have handwashed and when I dry the dishes the film is back. Please help I want to scream. Do I need to buy new dishwasher?????
just relax all you need to do is run a few load with tang brakfast drink run fauset till you get hot water put about a cup in the bottom and fill soap cup with tang you may run dishes with the tang NO SILVER JUST PLATETS AND GLASSES
Jun 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Culligan Under Sink Water Filter Logo
57 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Jim London
Jim London
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
