Question about Mitsubishi WD-73C8 73 in. HDTV LCD TV
Tv screen is getting darker
The image on the screen is getting darker
  • Mitsubishi Master
  • 3,904 Answers
Sounds like the back light lamp is going out. Check that.
Posted on Jan 20, 2013
Screen getting darker and color will not adjust
THIS LOT FAULT AJUSTMENT YOU ARE ELECTRONICS PERSON TAKE 25 W SOLDERING IRON RESOLDERING TO CRT NICK BORAD OR AJUST ON LOT, WATCH BELOW VIDEOS
NOTE:DONT TOUCH LOT ON SUPPLY
DONT TOUCH LOT&CRT LINKING PLACE WITH OR WITH OUT SUPPLY
SEE :LOT(LINE OUT PUT TARASFORMER) IMAGE ON GOOGLE
Mar 23, 2014 | Mitsubishi WS-65819 TV
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Our sanyo lcd tv is a couple of years old and recently when the tv is on for the first couple of hours the screen will flicker and get progressivly darker from the center of the screen to the left....
Hello; I am John at J. D. Electronics, Poland Maine. This problem is caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo and less than $400.00 from Encompass Parts Inc.
Oct 09, 2010 | Sanyo DP46849 46 in. HDTV
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
RCA TV RCA D61W20, Weird Problem
did you adjust the set in both modes 1080 and 480? They both need to be done seperately.
Apr 26, 2008 | Televison & Video
Tv screene getting darker and darker
Caps in high voltage needs changing, needs tech
Aug 19, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Mitsubishi WD-73C8 73 in. HDTV LCD TV Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
