How to replace the font panel on an Asko 10505
The front panel was broken, I fixed it and now I can get it back because of the detergent drawer being in the way. Can I take that drawer out?
  • 1 more comment
  • anne229
    anne229 Jan 20, 2013
    Hi, Thank you for your reply but it is not that simple I have to disconnect few pipes first. I think I am just going to take the Dispenser Drawer Handle. Do you know how to do that part?
  • B.H. Countryman Jan 20, 2013
    Perhaps i don't understand. I assumed you were refering to replacing the control panel face. If so the detergent drawer must come out. There are no hoses or pipes to disconnect, Unless you mean the entire detergent drawer assembly; but, that wouldn't be necessary to replace any front panel. Can you clarify?
  • anne229
    I am good I just took the Dispenser Drawer Handle out by breaking the tabs. Put the panel back in place and reglu the handel back in place. Thank you for your time!
    Sergeant:
  • 291 Answers
Yes the drawer will come out. There may be a trigger release way in the back. Use a butter knife or screwdriver to push down on the lever while pulling lightly on drawer. Let me know.
Posted on Jan 20, 2013
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
Macmarkus
  • 2605 Answers
SOURCE: asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Posted on Nov 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Replacing Motor Brushes, what needs to be done to
To clean the commutator, or armature as it is usually called, simply rub it with a piece of emery paper, or sandpaper, turning it by hand to ensure you clean it properly..
You need to remove the motor to do this of course.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
  • 3 Answers
SOURCE: water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Posted on Jan 31, 2010
SOURCE: detergent drawer will not open
The soap dispenser in my LG WM2277H front loading washer keeps getting stuck shut. I have tried wiggling it, jiggling it and yelling at it. Nothing works. I can not pry open the back as suggested and drill a hole. There has to be a solution! Please?
Posted on Jul 07, 2010
How can I open detergent drawer, opens about 20mm & won't come out any further
Pull the drawer out as far as it goes then lift it up and pull it out completely. It may be stacked due to detergent remainings.
So, you should clean the drawer with a soft brush under warm running water. Do not put the drawer into a dishwasher!
Replace the drawer by tilting it into position.
Hope it helps.
Jun 08, 2015 | Asko W6021 Front Load Washer
The detergent drawer is jamming and extremely difficult to open,any suggestions please?
Hi I would think its probably built up detergent in the runners take the whole drawer out and give a good clean use a steam cleaner if u have one
Mar 14, 2015 | Asko W6021 Front Load Washer
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
The washing machine doesn't open if I use detergent
read the side of the detergent box it normally says how much, and your washer is probably not opening because it has lid lock to open it you need to pause the cycle and wait a few minutes and it will release the lock also if the washeer is spinning or agitating the lid will automatically lock to open do as described above
Feb 19, 2010 | Asko Washing Machines
Asko 10505 will not spin the belt is not broken, tub fills and drains
Your washer unit is needing a new timer and replacement is needed if the part is available.
This will require some electrical experience to replace the timer unit or go to your local Sears repair and they will come out and repair your unit for a fee.
Jan 29, 2010 | Asko Washing Machines
Asko 10505 washer will not spin
Nov 01, 2009 | Asko W6021 Front Load Washer
Leaking inlet valve on Asko 10505
Unfortunately, the only way to be 100% sure this won't happen again is to replace the inlet water valve. Especially if the problem is intermittent. You could live with it if you turn off your water taps when the machine is not in use.
Feb 19, 2009 | Asko W6021 Front Load Washer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
