Question about Canon FAXPHONE B640 Plain Paper Bubblejet
Check Rec Paper
My unit will not pull paper from the back tray no matter what function I am requesting (i.e. printing a function report, copying a document, receiving a fax...). I have reset it, switched out the paper, put in a new ink cartridge, everything I can think of and I just can't get it to work. This has generally been a great product and I would like to fix it if I can. Any suggestions?
    Sniper:
  • 58 Answers
First power off the machine. Facing the machine from the front, remove the rear tray extension that holds the paper and "feel your way" down into the right side of the of the back paper tray. You should feel a out-of-round feed roller. With a little effort you can rotate this around. Take a terry like cloth and dampen it with water and clean this roller. Before puttin any paper back into the tray, turn the machine back on so the paper feed assembly will return to the home position.
Posted on Jul 19, 2007
  • Anonymous Jul 19, 2007
    "Trying to do it right the first time"
SOURCE:
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon FAXPHONE B640 Plain Paper Bubblejet Logo
484 people viewed this question
Clive
Clive
old marine
old marine
Ekse
