Question about Toshiba Satellite L25-S119 Notebook
Toshiba L 30 wan't booting
I have toshiba L30 series, wan't booting, power indicator on, hd indicator on for few second then shut down again then on again (repeatly).
please give an advise..
thanks before.
Remove or even replace cmos battery for 1 minute and should be back to normal. Worked for me.
Posted on May 20, 2009
My WAN port does not appear to work. (Data does not pass through it.)
Unplug the power to your modem and router boot the router up after 30 seconds wait for all the lights to turn on then boot up the router
Mar 02, 2014 | Linksys Wireless-G WRT54GL Router
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
How do I install addition ram in my toshiba satellite laptop L30 134
  • Shut down your Toshiba L30-10S.
  • 2 Unplug the A/C adapter and disconnect all external devices.
  • 3 Turn the L30-10S over and locate the battery pack at the top edge of the computer.
  • 4 Slide the battery release switch to the bottom right of the battery to release it. Set the battery to the side.
  • 5 Locate the RAM compartment door in the center of the computer.
  • 6 Remove the four screws holding the door in place.
  • 7 Lift the RAM compartment door off to reveal the RAM slot beneath.
  • 8 Lift the clips on the ends of RAM slot to release the current module.
  • 9 Slide the module out of the slot at a 30-degree angle and set it to the side.
  • 10 Slide the new module into the slot at a 30-degree angle and press gently down until the latches lock down and hold it securely. Replace the RAM compartment door and battery, then reconnect the AC adapter and external devices.
  • Dec 31, 2010 | Toshiba Computers & Internet
    I have toshiba satellite L30-113 note book i wan vga drivers to down load from net. I have tried but coudn"t get
    Hi, 1)Go to the below link. http://www.toshiba-india.com/laptop/DriversDetails.aspx 2)Under Product List, select Notebook Computers 3)Under series , select Satellite 4)Under Model select L30 5)Choose the type of OS 6)Under category select Display to download the VGA driver. 7)Good Luck
    Nov 29, 2010 | Computers & Internet
    My Toshiba L30 101 wont power up!!
    Solution is :-
    Please flip the notebook upside down , remove the battery , remove the ac adapter , then press and hold the power button for 30 seconds , then put the battery back , ac adapter back . try to power on the notebook it will work (i believe there is some static stuck in the capacitors of the notebook , which is not allowing it to boot.)
    If this will not work in that case :-
    You need to reseat the hard drive , and the ram of the notebook .
    In order to do so you can refer to this website .
    http://www.fonerbooks.com/laptop_2.htm
    If the issue still remains its a hardware issue , check the warranty and send it in for repair.
    Mar 18, 2010 | Computers & Internet
    Toshiba M45, no display, no boot, display button lights up about 3 seconds.
    I have same problem with L30/L35 mainboard
    did u find solution for your problem?
    /o\
    May 18, 2009 | Toshiba Satellite M45-S2692 Notebook
    Alienware Aurora desktop crashes on bootup
    try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
    Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
    Booting problem in acer 4520
    *********** board needs to be replaced
    Dec 08, 2008 | Computers & Internet
    I have an Averatec laptop, series 2300. While I was using it, it just shut down (immediate shut down) and wouldn't boot up again. I have removed battery, Let it charge overnight, and twice it has come...
    Are you just running it from the battery? It sounds like you may have a motherboard problem. I would first put in my OS boot cd and see if it boots from the CD. Let me know if you don't know how to boot from CD. If it does boot from cd then run a chkdsk /r on your hard drive.
    If that doesn't fix it I would see if the power supply is not working again are you running from the battery without power supply?
    Thanks,
    Henry
    Aug 19, 2008 | Computers & Internet
    Toshiba Satellite A35-S159 Shut down
    If it does the same thing when it's plugged in, it might be time for a trip to the service center.
    Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
    Toshiba Satellite L25-S119 Notebook Logo
    130 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
