Need motor for frigidaire fse747ges1 part #131511900 is there any other motor that will work?
    Sergeant:
  • 291 Answers
Check these out:
http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313&_nkw=5kh26jj064s&_sacat=0&_from=R40
Posted on Jan 20, 2013
Frigidaire washer/dryer combo, just the spin cycle does not work. A tech came and said the door latch needs to be replaced and asked him to replace it, but it didn't fix the issue. any help?
ok then the problem is much worse if the unit is belt driven and the motor can be heard still spinning you need a new belt installed about $150 plus otherwise if it is direct drive with no belt bad motor is the issue usually cost around $250 installed
Mar 13, 2018 | Frigidaire Washing Machines
Working but extremely noisy freezer
most likely noise is coming from evaporator fan motor.go here,it will show you the parts in your model,
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-PLFU1778ES0/1428/0142000/R0510085/00002?blt=06&prst=&shdMod=
unplug the freezer,remove shelves and remove back inside wall to get at the fan motor.you might see yellow stains around motor area,that's from the oil that leaked out of fan motor,also if noise stops and you notice that the freezer is cold on bottom and warm on top the fan motor died and needs to be replaced right away.hope this helps and you should change the motor out before you loose any food.
Dec 08, 2013 | Frigidaire PLFU1778ES (16.7 cu. ft.)...
FRIGIDAIRE FRS6HR4HW2 FRIDGE IS SOMEWHAT COOL BUT FREEZER IS SAME TEMP AS FRIDGE I HAVE POWER TO THE EVAP FAN BUT FAN IS NOT WORKING COULD THIS CAUSE THE FREEZER NOT TO GET COLD ENOUGH TO FREEZE
Yes, if your evap is fully frosted, and the fan is not working. The frosted evap will keep it cold but since the fan cant move the cold air from the evap it'll be cold, but not as cold as you'd like.
http://parts.sears.com/partsdirect/part-model/Frigidaire-Parts/Refrigerator-Parts/Model-FRS6HR4HW2/1428/0165000/R0607119/00005?shdMod=FRS6HR4HW2
there is the screen you need to order a new fan motor. option number 13 is the fan motor. lmk if u need more help!
Aug 05, 2013 | Frigidaire FRS26H5AS Side by Side...
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2012 | Frigidaire Dryers
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Frigidaire Gallery Gas Dryer model fsg747ges1 spins and stops. will not restart until motor cools. happens on all temp settings. What's up? Where can I find a service manual, so I can see how tricky...
Your service manual can be bought from this site => http://www.repairclinic.com/PartDetail/Service-Manual/948565
I can't give you a free one unfortunately due to copyright
The motor probably is shorted and so needs to be replaced which is why it doesn't work until cool. Let me know how this works out for you.
Benjamin
Jan 03, 2011 | Frigidaire Dryers
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Frigidaire Dishwasher
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Jan 19, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My dryer (frigidaire stackable washer/dryer) just stopped working, the washer is fine, but when I start the dryer nothing happens. I set the time and push the button and NOTHING.
Howdy: The circuit breaker could have popped in the motor. Maybe the selector on/off switch has gone south. Will need a AC meter to check voltages from switch to motor. Doug
Dec 09, 2009 | Frigidaire Dryers
Frigidaire fdb510lcs0 soap dispenser not opening
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once poweris applied to it. The BI-metal strip bends and allows the soap door spring toopen up the dispenser. This bi-metal strip is not given full 120 volts power,the timer "shunts" the power through either the heating element (most common ) or the motor and this gives the bi-metal strip lower than fullpower to work and open. Most often the bi-metal strip has lost its ability tobend properly and needs to be replaced. Older GE dishwashers used a mechanicalarm driven by the timer to open the dispenser = no electrical bi-metals.
Newer Frigidaire dishwashers and many newer Whirlpool dishwashers use a wax motor to open the soap dispenser. The plunger insidethe wax motor slowly moves and pushes the plunger and door open. And, if thiswax motor doesn’t receive 120 volts, then it’ll not work.
This will help you --
Please do rate this solution and revert for furtherassistance.
Thanks
Rylee
Sep 20, 2009 | Frigidaire Dishwashers
Washing Machines Logo
313 people viewed this question
Top Washing Machines Experts
