Question about Daewoo DVDS151 DVD Player
Daewoo DVD player keeps ejecting my CD.
When I insert a CD my Daewoo HC-6220 DVD keeps ejecting it back. It's an old DVD, and I haven't used it in a while. But the CD is clean and new. I also had this problem a year ago, and I think I did something with the wires behind and it worked. I need this fix today, so please respond! THank you
premtech
  • 934 Answers
SOURCE: Daewoo DV-6T955B VHS/DVD player problem
It's likely the spindle motor needs to be replaced. You can sometimes get a bit more mileage out of them by placing a tiny drop of WD40 down onto the shaft below the table and working that into the motor.
Bill
Posted on Mar 02, 2008
SOURCE: DAEWOO DV6T844B DVD player is "locked"
Press the power button on the remote control for about 8 seconds to lock or unlock the DVD player.
Posted on Dec 13, 2008
SOURCE: Daewoo DF 4100P not turning on but showing WAIT...
I had this problem yesterday, and then i noticed that i had accidentally put the timer on.  i had to unplug before i could release the dvd and set the machine up again.
Posted on Jan 12, 2009
SOURCE: This player is incompatible with the region marking of this disk.
go to setup. scroll over to systems info. on remote press 1-1-0-1. It will bring up region code. type in "0" for region free. It works I did it.
Posted on Jun 06, 2009
RixsFixes
  • 2200 Answers
SOURCE: Daewoo DVDS130 player says 'No Disc' after it has already loaded
Hi
The drive is not reading the disk. This is either caused by a fault in the laser/lens/drive itself or caused by dirt in the drive effecting the lens.
There is a Laser cleaning DVD that you can purchase from any audio shop - its not expensive and useful to have around anyway. I would recommend you try one of these and you may find that it will resolve the problem as a simple and quick fix.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 16, 2009
Door will not open
this product seems to be an audio CD player in use with a stereo system.
Have you tried inserting a paperclip (that has been straightened out) through the tiny hole available to manually coax the tray to come out. It will pop out just a little, but it will then be unlocked and be easy to bring out, displaying the entire CD.
If you have tried that, then.....
Take the cover off (the entire case) and inspect the area where the CD is. Many of these players have no metal encasement around the CD mechanism and one can see the inner workings. The CD may have gotten askew, or the mechanism jammed. Gently try to free things up.You should at least retrieve your CD.
Put the thing back together. Use a junk cd (keep the stereo amp off) and try to load and unload it. If that fails.... Time to get a new one.
Here's a suggestion for that. Most all DVD players handle cd's. Purchasing an inexpensive DVD player might be cheaper than finding a stereo component CD player. Just use the audio out.
Good luck
---Sam
Oct 04, 2012 | NAD C521 CD Player
Can't get green standby light to stay on, so can eject DVD from combined TV and DVD player.
First try unplugging and plugging back in then remove caseing and insert paper clip under locking mechanism and hit eject...your locking mechanism signals that there's no cd in it and so to it there's no dvd or cd...hope that helps:)
Jan 04, 2012 | Televison & Video
CD stuck in DVD player in tv
I'm sorry that the disc tray is not ejecting. Please check whether you're able to locate a small hole under the tray opening area. If one available, please insert a pin and it will eject manually now..
Dec 18, 2011 | Televison & Video
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
I need a new firmware for Daewoo DVD hc-6120 ux
I have problems too with my Daewoo HC-6120ux. It doesn't render properly some of my DVDs. Where can I download an update for it?
Feb 09, 2009 | Dual Televison & Video
I have a Daewoo DF-4100P DVD/VCR combo. I have inserted a DVD that is unplayable. the disk just keeps spinning then gives up ..but I an unable to eject the DVD. I have tried resetting the DVD player. Is...
Hello there. I know you said that you tried resetting the unit, but have you reset it then pressed the eject button rapidly as soon as you press the power button. This usually works for me.
Dec 03, 2008 | Televison & Video
Daewoo DVDS151 DVD Player Logo
44 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
