Question about Mercedes C-Class Exterior Pillar Posts Trim Set
Disconnected battery in wrong order esp warning limp mode
    Genius:
  • Mercedes-Benz Master
  • 1,138 Answers
This wouldn't normally cause the light to come on try disconnecting it again leave an hour then try reconnecting earth first might solve the problem
Posted on Apr 02, 2015
Hi, have a citroen Ds3 dsport...anti pollution fault, asr/esp, limp mode...need to get out of limp mode to accelerate to clear system... Need help as it's driving me nuts!!!!
the limp mode will not allow you to accelerate until you have fixed the problem and reset the ECM
Limp modes are not there to help ease you frustrations but to prevent costly repairs to the engine and transmission
fix it , reset it then you will have no need to go nuts
Aug 13, 2016 | Citroen Cars & Trucks
Esp bas light on what is that
our Electronic Stability Program (ESP) Indicator Light / Brake Assist System (BAS) Warning Light is a common issue with Chrysler's. The first thing to check is the electrical system. Remove the battery posts and clean them well. Next is to check the ground connection at the bulkhead, under the hood and the positive connections at the fuse box and boost pin. If all that checks out OK, check under the main fuse box for loose / corroded plugs and wires. These are the known, common problems. The fluctuation in power would cause the PCM to momentarily go into limp mode causing bucking on decell. Also have the OBD trouble codes read, including the ABS system.
To reset the ESP/BAS light, with the engine running, in park turn the wheel right to left, lock to lock twice.
Nov 11, 2014 | New 2006-2010 Chrylser 300 Chrome Grille...
Mercedes benz limp mode
WHEN YOUR VEHICLE GOES INTO LIMP MODE IT INDICATES A PROBLEM THAT NEEDS ATTENTION CAN BE TRANS OR ENGINE TRY TURNING SWITCH OFF AT A STOP AND GO AGAIN WITHOUT HOTRODDING IT. THERE ARE TIMES WHEN WIPING AROUND DANGEROUSLY IT WILL GO INTO LIMP MODE.
Oct 30, 2013 | Mercedes-Benz ML320 Cars & Trucks
4WD warning light, Esp off, check engine light all comes on then it gores into limp home mode P1155
Google the codes you get
OBD P1155
All the causes & solutions are on the internet
Sep 01, 2013 | Hyundai Cars & Trucks
1 month ago my x type went into limp mode. Mechanic had it for three days and could find nothing wrong. Then today it went into limp mode four times. No warning lights on dash
The only time a vehicle goes into limp mode is when there is ****** problems, so I would take it to the ****** shop for code retrivel and if I am not wrong there might be problem with the Input/Output speed sensors BUT do have it checked first.
Sep 16, 2011 | Jaguar X-Type Cars & Trucks
I have a 2004 grand prix 3800 engine non turbo. Engine was eratic at cruise with rpms at 1200-2000. rpms would lope 2-300 rpms. I Changed air and fuel filter, and cleaned the throttle body. also checked...
i had a problem with all my lights coming on in my 2006 explore took it to dealer to find out that the battery was dying replaced it and they went away
Mar 26, 2011 | 2005 Pontiac Grand Prix
2002 Impala: transmission limp mode...
Most transmissions have a limp mode, or limp-home mode.
If the driveline computer thinks there is something wrong, it can lock the transmission into one gear, such as 2nd gear. Usually reverse will also be available. The Impala automatic has 4 speeds. 2nd speed or gear will get you home, but the engine rpms can get a little high. I wouldn't get on the expressway will in limp mode.
Before taking to the shop, you might want to try and reset limp mode by turning the car off for a couple minutes, or you may have to disconnect and reconnect the battery.
May 16, 2010 | 2002 Chevrolet Impala
I have a yellow triangle with an exclamation mark
ESP = Electronic Stability Program malfunction indicator lamp (MIL)
1. You can try to disconnect the battery from car terminals, waiting for 30 minutes and connect again the cables in order to reset the ESP Electronic Control Unit (ECU).
2. If this procedure does not work you must use a diagnostic equipment connected to the Data Link Connector (DLC) of the car. The ESP ECU fault memory can only be accessed and erased using diagnostic equipment connected to the DLC.
Note: ESP function includes ABS (Antilock Braking System) function!
Mar 31, 2010 | 2002 Audi A4
2001 grand prix v6 check engine light stays on
Have you tried disconnecting the battery for at least 30 minutes? This is sometimes the case and the computer just needs to reboot. If that doesn't work, your o2 sensor has probably gone bad. Its not an expensive fix. Leaving the check engine light on puts the computer into a setting called "limp mode". Limp mode is a safety to prevent damage to your vehicle. In this case the computer thinks there is something wrong and by going into limp mode tends to give you less gas mileage and less power performance as well.
Mar 31, 2009 | 1997 GMC Jimmy
1997 isuzu wizard mu check light
Code 24 is a vehicle speed signal sensor fault, the sensor most likely does not provide a useable signal until about 25 MPH, when the computer doesn't see any signal after that speed it turns on the light. Make sense?
Sep 08, 2008 | 1997 Isuzu Oasis
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
108 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
