Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Dirt Devil Easy Steamer Deluxe
When I use my Dirt Devil Easy Steamer and I pull the trigger to release the cleaning solution, the solution comes out like it is supposed to, but it doesn't stop when the trigger is released. I took it apart and just can't figure out how the trigger assembly is supposed to work.
  • 1 more comment
  • Anonymous Mar 23, 2014
    the part that covers the hose came out.. it is a black cover with a coil that goes both ways. I cannot figure out how to put it back in
  • Anonymous Mar 24, 2014
    How do I take apart model sd200000 so I am able to do corners and cushions. I keep trying to figure it out please help
  • Anonymous Mar 26, 2014
    quick release not working, cannot get canister out of machine to empty
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
SOURCE:
How to fix dirt ***** easy steamer deep cleaner, it is leaking water?
Hi there! Check the clean water tank valve to see if that is where the leak is coming from. If so, your clean water tank will need to be replaced. If the leak is coming from somewhere else we recommend taking the cleaner in to a Dirt Devil authorized service center for repair. I have included a link where you may locate the nearest service center to you. Hope this is helpful. If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Service Center Locator
Aug 22, 2014 | Dirt Devil Featherlite Easy Steamer Extr...
Dirt devil carpet steamer diverter valve not releasing for furniture attachment
Hi there! If the trigger or valve are sticking this can be an indication that the valve may be clogged with soap residue. Try soaking the trigger end in warm water for a few hours. When you use the hose again, be sure to prime the trigger by pumping it about 30 times then squeezing it for 30 seconds to get the solution to flow. Hope this helps!
Jun 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
Why will my Dirt devil easy steamer not releasing cleaning solustion
Hi! You may need to prime the trigger to get the solution flowing. To prime the trigger recline the handle and pump the trigger vigorously about 30 times. Power the cleaner on and hold the trigger in for 30 seconds. Be sure you are only using the Dirt Devil cleaning products intended for use with this machine. Using something other than the specified detergent can clog the lines that deliver the solution. If your cleaner still isn't dispensing you can take it in to a Dirt Devil authorized service center for repair. I have included a link where you may go to locate a service center near you. Hope this was helpful!
May 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
What? I have a Dirt. Devil easy steam carpet shampooed model CE 6300 HD. It was working great and then just stopped spraying out cleanser/water! Is there a manual or does anyone know how fix this problem?
Hello! You may need to prime the trigger to get the solution to start flowing. To do this, recline the handle and pump the trigger about 30 times. Then, turn the cleaner on and hold the trigger in for 30 seconds. The solution should begin to dispense. Be sure you are only using the cleaning products specified for use with this unit. Hope this helps! If you still need assistance feel free to reach out to use here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
May 09, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
I have a Dirt Devil easy Steamer delux,but lost the owners Manual,forgot how to use it ,can you help ?
I believe the following manual is for your machine. It's model # MCE6600. It's what comes up when a search is done for Easy Steamer Deluxe.
http://www.dirtdevil.com/manuals/?id=c6f182b2-b418-447d-951f-ca9456153b3d
Jan 10, 2011 | Vacuums
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
I need a new manual for dirt devil easy steamer deluxe
CLICK HERE for the owners manual in PDF format.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
1,447 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
