Question about GE Spectra JBP78 Electric Kitchen Range
F2 error code on GE Spectra JBP78
Our power was lost for 5 days and when power was restored and the electric kitchen range came back on I got this F2 error code. How do I fix this?
    Top Expert:
  • GE Master
  • 9,472 Answers
F2 indicates that temperature inside the oven has gotten to high. Pull the temp probe and check to see if it has 1100 Ohms. If it does, you will need to replace the control board.
Here is the probe to order if it is bad.
Here is the control board to order if the probe is good.
Keep me posted!
Posted on Jan 19, 2013
4 Suggested Answers
bbtoast
  • 319 Answers
SOURCE: GE Spectra JBP78 Electric... Problem:
Try pulling hinge locks down to unlock.
Brian
Posted on Aug 01, 2008
mreid542
  • 166 Answers
SOURCE: GE Spectra JBP78 Electric Kitchen Range
This should be a smooth top range. Smooth tops don't lift for cleaning - only for servicing.
Posted on May 29, 2010
blackmar
  • 235 Answers
SOURCE: the large electric burner on GE spectra model
This would generally be a hotplate controller problem. If this is a normal hotplate then we know it is okay because it is working. The controller sounds as though it is faulty.
Posted on Feb 11, 2011
F2 beeping
F2 indicates that temperature inside the oven has gotten to high. The sensor should read around 1000 ohms at room temperature if not it is bad. Here is the part to order.
Mar 17, 2013 | GE Spectra JBP78 Electric Kitchen Range
What does code F7 mean?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 13, 2011 | GE Spectra JBP78 Electric Kitchen Range
Error code f2 broiler comes on by itself and won't shut off
F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
GE spectra jbp66 oven is off but F2 error comes up and oven turns on and wont turn off. ive already unhooked and rehooked temp probe and took out the plastic connector and used wire nuts instead and...
Hi There
I have found this for you to read and hope this helps you.Let me know how it goes.
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | GE Spectra JBP78 Electric Kitchen Range
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
Jul 29, 2008 | GE Spectra JBP78 Electric Kitchen Range
F2 CODE BROILER ELEMENET WILL NOT TURN OFF
Either the relay on the control board is stuck and allowing power to the element or the element is shorted to ground.
Nov 10, 2007 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
