Question about SanDisk Sansa e260 MP3 Player
Screen is green
Yesterday i unplugged my player and after saying "refresh database" the screen went green and little boxes were moving across the screen,the blue ring wont turn off and i dont know what to do?
  • 32 Answers
#1 Try resetting it by holding the power button for 15 seconds.
Posted on Jul 17, 2007
  • Anonymous Jul 17, 2007
    or if not try reinstalling the firmware (what makes the mp3 work). On the sandisk website, there is something called sansa connect recovery tool, and there is a manual on how to use it. download it, it will repair ure problems. Go to the sansa connect recovery tool here : http://www.sandisk.com/Retail/Default.as...
SOURCE:
Hellp !
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 23, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 - Stuck on "Refresh Database" after uploading music
or
http://www.sandisk.com/DriverDownload/driverList.asp
Apr 19, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database hang up and screen turn black
Go ahead and do this, in case the DB is corrupted:
Mar 08, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Blank Screen After Database tries to refresh
If you tried everything you could then Format the player. It will erase everything and will Very much fix anything wrong with the player. To do That go to start>my computer>Mp3's Drive. Probably a Letter like (F:) or (G:) which ever the mp3's drive is. Then Right Click on the Drive and Click Format. it will ask if you want to format, as it will erase everything. Click yes and perform a "quick format" when done. safely disconnect from the computer and restart. then load the songs. It should work then. Hoppe this worlks. :]
Jan 11, 2008 | SanDisk Sansa e260 MP3 Player
MP3 not being recognized by computer
My opinion.
No one here seems to understand the question...unless it's just me.
Not being recognized by computer means you should not be able to disconnect the device safely. Am I right?
I cannot seem to disconnect the device safely, which means that the refresh database option will not display and do so!
Help?
Nov 06, 2007 | SanDisk Sansa e260 MP3 Player
Refresh database
Sansa e200 provides a RESET function for unresponsive units. Press and hold the MENU button for 15 seconds, and this should work to regain normal funtionality. Please note: settings and adjustments from the last operation WILL BE LOST. The files however should remain.
Sep 19, 2007 | SanDisk Sansa e200 MP3 Player
Refresh Database Problem
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Aug 21, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e200r
my Sansa M200 has a frozen screen, tried removing battery but comes back screen frozen
Jan 04, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
136 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
