Question about Garden
Only one wheel runs in gear on my snowblower
Tire was flat wheel was seiged on axel Had to take gear chains off so we could beat out the axel to get wheel off. Fixed tire and put back together still blows snow great but we must have missed something....Now only one wheel is gear driven and can't pull itself forward to blow snow....also it rolls back ward when in forward gear....help need to know what we screwed up putting it back together
    New Friend:
    Problem Solver:
  • 14 Answers
Sounds like the key that locks the wheel to the axle shaft is missing. Look in a parts manual that came with the snowblower to see the key. Should be with the transmission break down or the wheel and/hub breakdown. If you do not have a parts manual depending on what brand and model you have, you should be able to find it on line.
Posted on Jan 21, 2013
trippssmengi
  • 76 Answers
SOURCE: will not engage foward or back .
Remove the cover on the very bottom under the engine, you will see a wheel with rubber ( the friction wheel ) on it, when you squeeze the handle for the drive you should not be able to turn that wheel by hand. First check to see if there is enough rubber extending from the metal disk it is attached to, if there is then it might be just adjusting the drive cable till the drive disc grabs the friction wheel sufficiently. If there isn't enough rubber or the rubber is chewed up you may need to replace the rubber part ( if the disc has screws in it to be able to seperate) or replace the whole wheel ( if the disc doesn't come apart ).
Posted on Jan 14, 2009
EarthJam
  • 23 Answers
SOURCE: Screws on my Sears track drive snowblower unthread themselves.
Back wheels have a gear that connects to the drive chain. on each side. those spin.
The front ones which are Idlers do not spin as the idler wheel as a bushing in it that allows free motion on the shaft without resistance. Use a nylock nut with Locktight for starters. The try that.
Hope this helps. -Jeff anchorage small engine repair.
Posted on Feb 03, 2009
  • 133 Answers
SOURCE: I need the owners manual for an Ariens Snowblower
You might need to change the friction wheel. I looked up your model number and the part number for the friction disc is PN# 240394. You might be able to get the part locally from your small engine repair shop.
To replace the disc you will need to drain the oil and place some plastic over the gas tank and put the cap on so no gas will leak out. Then you will have tip the blower forward so it is setting on the augers.
Then remove the bolts on the access cover on underside . Once removed you will have to remove the wheel and see what else you will to remove. It is pretty easy to figure it out. If you have to take out the rod that moves the friction disc from side to side (gear shift rod) MAKE SURE IT IS IN PLACE AND WORKING BEFORE REASSEMBLING. Put in fresh oil and remove plastic. It should be up and running.
Good luck let me know if this helps.
roundo4
Posted on Aug 14, 2009
SOURCE: broke the chain , on snowblower
top idler sprocket was out of alignment,staitened plate it was attached to, then chain was running true and went on just fine. it was an old wheel horse snowblower.
Posted on Dec 16, 2009
  • 150 Answers
SOURCE: Ariens SnowBlower I recently blew a
Hi dwva, I think you have the belt on properly seeing the other gears work fine. The difference between 1st and reverse can be as little as 1 half in on the drive wheel. It depends on which side of center is the friction wheel riding. Remove bottom pan with the machine in 2nd or 3rd gear notice which side of center is the friction wheel riding. (the friction wheel is the one with a rubber outer ring). Now put it in 1st, is it on the same side of center? There is an adjustment on that linkage, adjust so in 1st is on the same side of center. Happy New Year, hope that helps.
Posted on Dec 29, 2010
Testimonial: "Thank you for the advice worked perfect"
How to take axel out of rear wheel 2009 Yamaha 950 have muffler off wheel nut off but doesn't want to come off need help please
Undo the axle nut..the brake lever,and the brake support arm,then drive the bolt from the right to the left using the ratchet handle and a beating device.
The tire then is just sitting on the gear mesh,pull it from the right ,and it drops right off
https://radmfg.wordpress.com/2011/02/07/ktm-950-cush-drive-rear-hub-specs/ KTM 950 Cush Drive Rear Hub Specs
Apr 22, 2015 | Yamaha Motorcycles
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
Feb 11, 2015 | Mtd Garden
Steering pulling right
Hi Anonymous, top of the food chain rear wheel alignment, bottom feeders, abnormal front tire wear, loose spokes, neck bearings loose axel, off center loading, improper tire pressure, unbalanced wheel, wheel out of round, excessive wheel bearing end play. Take your pick and good luck.
Apr 16, 2014 | Harley Davidson FXSTS Springer Softail...
Won't just stay in one gear. constantly doing gear changes on its own. Hardrock. Rear set, reguardless of which front gear.
This happens when the back wheel is not aligned properly with the chain. As the wheel turns the chain is being pulled to one side causing it to slip to the next set of cogs. To solve the problem first you need to loosen the wheel by opening the 2 nuts on the axel. If the chain slips inwards towards the wheel you need to move the front part of the back wheel to the left from a view point behind the bike. If it slips outwards away from the wheel then you need to move the front of the back wheel to the right as viewed from behind the bike. When the chain and cogs of the rear wheel are lined up in a straight line the problem should be solved.
Dec 04, 2010 | Specialized Bicycle Components Cycling
How do i tighten the chain
lossen nuts on rear axel(rear tire) and tighten your chain tensioners(one on each side) untill it tightens,then retighten nuts on axel..(do not tighten chain to tight,should be a little loose) and make sure the chain adjusters are even on each side so wheel is straight or it will dog track(pull to one side or the other....) happy trails!!!!!!
Aug 09, 2010 | 2005 Honda CRF 150 F
Both rear wheels are "frozen" onto the axel/brake housing. I am trying to change a flat tire and cannot get the wheel and rim off. The truck is in my heated garage so the "frozen" is not water/ice but...
the wheel is corroted to the drum the only thing you can do is get a very large hammer and beat the back side of the tire untill it comes loose. when you get the tire off go get some never sieze and put it on the wheel were it meets the drum
Dec 30, 2009 | 2004 GMC Sierra 2500
Broke the chain , on snowblower
Dec 15, 2009 | Garden
Right rear axel makes noise
You need to jack it up, And put it on jack stands. Its a safty thing. Next spin the tires with the engine, Put it in drive. let the Brake off slow. Don't forget to block the front tires with a brick, or a 4x4 or 2 pieces of fire wood. Put one under each front tire. Now run the engine 30 to 35 miles per hour.With the tires still on your Rover. Pay close attn to the noise as the tires spin. Now pull the wheels and pull the rotor or drum off. Now if its a bearing you will here it. Be sure to let off the gas pedal very slowly so you won't hurt the drive train. We checked wheel balance, Wheel bearings, Brake noise, even out of round tires can be spoted while running the tires on and off to do the test. its like driving it down the road but you can get down there and look and hear things. I sure hope this is helpfull to you.
Aug 18, 2009 | 1999 Land Rover Range Rover
Have flat tire for Honda Shadow vlx 600
Remove axel nut loosen chain tesioners get a friend to hold the break up if it is on the axel so it doesnt fall on your paint. >< pull out axel lift chain or belt off the rear drive and have friend get you a beer. Thats how I do it.
Jul 07, 2009 | 1993 Honda VT 600 C Shadow
Feb 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
