Question about Dishwashers
Kenmore dish washer leaks thru the door, need replacement seal.
Disher washer leaks water on the the floor every time I run it. Water is coming thru door seal.
Thanks, Kurt
  • 56 Answers
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Posted on Jan 26, 2009
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Kenmore elite dishwasher leaking below washer
see this causes and use the common sense. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a Whirlpool Gold GU3600XTSY0 Model. There is slow water leak from the right side bottom front of the dishwasher. It looks like the water is leaking from a sensor on the bottom. The sensor has a...
I would look at the door seal being a problem as well. if the water level float were leaking, it would be worse then just a little water. The door seal is always the first to go. these seal can be replaced by pulling the old one off and pushing the new one back in place. should be able to buy new seal from the people the unit can be bought from.
Dec 19, 2010 | Dishwashers
Disher washers starts and then stops and ECO 40 flashes.
sounds like water in the base has caused the safety float switch to activate try tipping unit backwards if water comes from base this is causing the problem if water has leaked past the door seal intermittently it will eventually collect enough in the base panel to activate the safety float switch tipping the machine and emptying any water in the base should clear the problem however if you experience the same problem within a short time period then it probably means that a hose or component is leaking into the base panel and would to be found resolved
Apr 11, 2010 | Hotpoint 24 in. FDW60 Free-standing...
When washing dishes the dish washer leaks water? lots of water
it sounds to me like you need to check the seals underneath the dishwasher.
Oct 16, 2009 | Dishwashers
1991 Suburban has water leak on drivers side floor when it rains.
check out your door seals may need replacing. drive it thru a carwash to locate the spot.
Mar 05, 2009 | 1991 Chevrolet Suburban
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Water leaking from bottom of door during wash cycle
this will more likely be your door seal open the door pull your seal so u can see inside and feel around as u look u will more than likely find a hole the water looks like it comes from somewhere else but it will be from the hole in the door seal seen this with hundreds of washers m8
Aug 26, 2007 | Kenmore 43142 Front Load Washer
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Dishwashers Logo
249 people viewed this question
Top Dishwashers Experts
