Question about Sansui G-5700 Tuner/receiver
Sansui G-5700 protection light wont go on
I have a Sansui G-5700, I was listening and I turned up the volume a little and it just shut off. I turn the power button back on and it turned on and it did the same thing a couple more times and it wouldn't turn on now, so I opened it up and replaced a broken fuse so now it turns on but no sound will come out the speakers. The "Safely Operate" button will not light up either. I also smell a little something from the rear of the unit. Please Help!
  • ron lambord Jan 21, 2013
    I disconnected my speakers and the "Safely operate" button is still not on at all even if i turn up the volume, so i dont think it will put out any sound until we find out why that isnt on.
    New Friend:
  • 4 Answers
I had a very similar problem with my Sansui G5700. Powers on, but no sound. My solution may not fix your problem, but this is what I did to solve mine. Removed the wooden cover. On the main power circuit board ( near the main transformer) there is a safety relay that activates the power to the speakers. Carefully remove the plastic cover ( should come off easily) spray the contacts with contact cleaner. ( do not use CRC. use a dedicated contact cleaner) Double check all your fuses. Refit the plastic relay cover. Refit the main wood cover. Power on, and hopefully it works :)...Mine has not missed a beat since.( If this didn't work, check if the relay actually switches on and off. The relay may have an open circuit and needs to be repaired/ replaced)
Posted on Jul 16, 2014
    Problem Solver:
  • 17 Answers
Try checking the speakers and connections. Those symptoms occur if there is a short. Disconnect all spkrs, turn it on and if it stays on connect one speaker at a time until it shuts off.
Posted on Jan 21, 2013
5 Suggested Answers
  • 2336 Answers
SOURCE: I have a sansui G9700 receiver/amp. The volume
The potentiometer doesn't need to be replace, it has collected dust inside causing the intermittent operation. Buy a contact cleaner/conditioner to spray inside it and move the potentiometer clockwise and counter clockwise a few times until the dust inside it is gone.
Check this link to find a contact/conditioner cleaner or you can try spraying rubbing alcohol but this could because alcohol doesn't not lubricants properties.
Let me know if you require further assistance.
Posted on Nov 27, 2010
technical114
  • 1851 Answers
SOURCE: Hi . I was hooking
There is no doubt, something burned out at your Sansui. Disconnect everything from the receiver and check at the back panel for any fuse holder. In case of existing, pray to be blown and check the fuse. In case of blown replace WITH THE SAME CURRENT RATTING. Without connecting anything but the power start it up AND BE READY TO TURN OFF in case of a failure. If everything (led, panel, lights) are working plug in a pair of headphones and check for audio. If ok, power off and connect with maximum care speakers (check out for short circuit at the terminals) and the rest. If not, there is internal damage; I don't pray for this. Keep me updated with ANY results..
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: I am fixing a sansui
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Posted on Dec 31, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Sansui 717
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 23, 2011
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
https://www.ifixit.com/.../What+do+I+check+if+my+Sansui+TV+M...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Sansui sty1232 it block in standby mode
Try unplugging your TV from the electric socket for a few hours or preferably overnight. Hopefully your TV will then turn on
Oct 04, 2014 | Sansui Televison & Video
Buzzing sound from hdlcd185w series A
Return tv to store for exchange or call Sansui customer service. They will arrange to exchange tv.
Jan 27, 2012 | Sansui HDLCD-1900 19 in. LCD Television
Sansui sv-2012 tv volume is very low and suddenly increase
Hi srinivas_327,
This is common for some sansui televisions,
All you need to do is to go in the audio settings and turn "ON" the AUTO volume option .
This will help all your channels to have a similar volume , so you won't be surprised by sudden increase in volume.
Hope this helps ...:)
May 10, 2011 | Televison & Video
I have a Sansui 717 Receiver/Amplifier. Everytime I turn on the power it will warm up for a few seconds...the blinking will stop and ready. I try to turn the volume up and it cuts out immediately. Can this...
Jan 23, 2011 | Sansui Audio Players & Recorders
Sansui 13" DTV1300 shuts itself off
My girlfriend had the same issue with her 1300a. We saw on another forum that they took off the extra AV panel and infared receiver, so we opened it up. We couldn't really find either, but when we tightened all the plugs up things seem to be working fine again. Back to watching the Lifetime channel :(
Mar 18, 2009 | Sansui DTV1300 TV
Sansui TVM1902A
Try codes for Orion.
Aug 27, 2008 | Sansui DTV2760 27" TV
Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
May 04, 2008 | Sansui COM311AD 13 in. Combo
Sansui G-5700 Tuner/receiver Logo
341 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
