Question about Compaq Armada 1598DMT Notebook
How do get the boot cd option - Compaq Armada 1598DMT Notebook
Reboot with cd
Hi Friends
If you want to Boot your computer from CD or DVD in this case you have to set the "Boot Sequence" from BIOS. Follow then mention below instruction and try.
  1. Restart you Computer and press the "Del" key from when computer is boot.
  2. Your will see one Blue Screen with lots of option.
  3. Select the "Boot configuration" and select "Sequence"
  4. There you will see some option like "First Boot :- HDD, Second Boot:-CD-Rom, Third Boot :- Floppy Drive. ect.
  5. So what you should do you just select the "First boot :CD-Rom"
  6. For move the option you see the down help windows and configure the boot sequence .
Thanks to Visit Fixya...
Sep 07, 2012 | Lenovo 3000 Y410 Laptop
HI, i can not boot from usb cd-rom. My internal cd-rom dont work but i need to install windows again. Can you help me? Thanks
press F2 when you restart your laptop but for desktop press DEL when your computer is starting up to get it to the BIOS then look for BOOT OPTION the make the USB CDROM on top to make it the first boot.
or
insert your Windows Operating System CD and restart your computer then press F8 multiple times and it will give you option to select CD ROM to boot from
Sep 11, 2011 | ASUS A2H (A2HOB) Barebone
Comes up no opererating system.sees hard drive and cd rom.does not read vista disk in cd rom.know cd of vista good,do i just need to change out cd rom drive?
I think your PC is trying to boot from a hard drive without an operating system.
You'll need to change the boot option in the bios from HDD to CD.
When the boot screen comes up, look at the bottom of the screen, it'll say something akin to
Select "DEL" for SETUP or F2 for boot options, you can use either, but remember if you choose to change the setup, it will be a permanent change until you reset it.
Hit the requisite button, read the screen to change "The first boot device" to CD. If you change just your boot option, your pc should then boot from the Disk.
If you decide to change the bios (setup) settings you'll need to save and exit. Unless you're very sure, just change the boot option for now.
Mar 26, 2011 | Dell Inspiron 530 Desktop Computer
Hp pavilion a530n will not boot for cd it says not hard drive found reboot and select proper boot device or insert boot media in selected boot device
Need to set it to boot onthe CD drive.To boot on CD drive;
1-at start up press F2
2-At BIOS select BOOT option and move the CD drive to the fist option using the keyboard arrows.F10 to save and exit.
Oct 26, 2010 | HP Pavilion A530n (DW234A#ABA) PC Desktop
How do I install Windows 7 etc on new Asus 5X DC
get the windows 7 cd, put it in the DVD drive, watch for boot options when the computer starts something like "press F9" for boot options. Its typically (F9-F10 or F12) select boot from CD Follow the prompts. If you cannot locate the boot options. Go into System Setup at boot and change the BIOS Boot order, To CD first then hard disk. Cheers
Aug 25, 2010 | ASUS Computers & Internet
Wont boot, not even from CD, won't open setup or boot options
At first you insert your system disc on your cd/dvd rom driver and restart your computer. Now press F2 or DEL until you get your BIOS option. Now go to advance option then boot option in that. Now change your first boot option to CD/DVD ROM DRIVE and save that change by pressing F10. Now restart your computer and continue your installation. Thank you.
Jun 10, 2010 | HP Media Center m7250n (ED842AA) PC...
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
May 04, 2010 | Microsoft Windows XP Professional SP2
SYSTEM SWITCHES ON AND DETECTS ALL THE HARDWARE BUT WONT GIVE ME THE "PRESS ANY KEY TO BOOT FROM CD-ROM OPTION"
Some computers allow you to select an alternate boot device by pressing the F12 key as you boot up.
If your computer doesn't have this option then go into the BIOS configuration and change the boot order and make the CD-ROM the first boot device and the hard drive the second boot device.
Aug 14, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
APPLE MACBOOK WOULD BOOT. THE BOOT CD IS
unfortunately on the newer mac computer including the macbook you cannot boot to open firmware but there are other options
option 1)simply try holding down the mouse button or track pad button during boot after the first chime is sounded this will instruct the computer to eject the cd through the firmware
option 2) you can bypass the cd boot by holding down the option key after the first boot chime another simple solution this will allow you to choose a startup disk during...startup after which you can try the eject button on the keyboard or select the disk in finder and eject via trash can or eject symbol(symbol located in the open folder view of finder)
option 3) there is also a manual eject button though it may be harder to locate as they have change placements of it over the years however it can usually be found by probing the top center or far right of the cd slot with a paper clip just be gentle you don't want to damage an expensive piece of equipment by just carelessly jamming metal in it
you may want to try searching apple with your particular model and search for manual cd eject
best wishes, Crash
Apr 24, 2009 | Apple MacBook Mac Notebook
Boot from CD does not work.
You should definately be given the choice to boot from cd, when you press F2 to get into the bios and go to boot options, what boot options do you have?
If you go into the bios you should have the choice to boot from ide (hard drive), cdrom, floppy disk, network (on some) and try other boot media.
Are you going into the boot option in the bios by pressing F2.
Jan 14, 2009 | Compaq Evo N610C Notebook
Compaq Armada 1598DMT Notebook Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
