May have head gasket or centre manifold gasket leaking .. remove one spark plug at a x , check to see if it,s oily.. replace each one back so there,s no confusion after u checked all ..while ur doing each one, do a compression test to each cylinder to check if u have worn out piston rings .. gd luck ...
It seems the source of the oil leak is coming from the exhaust valve.
Could it be the valve stem seal or maybe the valve guide?
