Question about Lexmark X83 All-In-One InkJet Printer
Carrier Stall is the error
I have an lexmark X83 and after I replaced the ink cartridges the carrier now slams and it has an error that says "carrier stall Press power Key" . If you press the power key, it thinks for a minute and the carrier slams again and you get the same message. How do I fix it?
    Sergeant:
  • 320 Answers
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Posted on Jan 27, 2009
Lexmark x83 carrier stall
Hello there.
I have checked lexmark's website on troubleshooting this problem for you.
As per the link here we need to try the following steps to resolve the problem.
Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Let us know how this goes and we can assist you futher, if the printer is damaged and is under a year old, lexmark may be able to repair or replace it for you.
Hope this helps.
Jun 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
After replaceing an ink cartriage every time I turn the printer the ink tray slams to one side then all the way back I gert an error message to start it again and slam bam. I hope you can help.
The encoder strip may have come out of the sensor slot. Turn off power, slide cartridge carrier to center, place finger on each side of encoder strip which runs behind the carriage and push the encoder strip down and back up, slightly back and forward if necessary to get it into the sensor slot which is located behind carrier. If it is in slot, sliding the cartridge carrier back and forth to see if therre is movement. If so repeat.
Dec 26, 2009 | IBM Lexmark X83 All-In-One InkJet Printer
The printer carrier slams to the right, when i try to print, and the readout says , carrier stall
A gear in the carrier is stripped or has fallen out of place.I've had this happen on several ink printers where the in-users jammed the printer and then forced/pulled the print head. You can often take these apart and get them serviceable in the short term. But once they break they don't last. I don't know what model printer you have specifically and I've never bought the parts for replacment, but in most cases it isn't worth the effort.
Jul 30, 2008 | Lexmark Office Equipment & Supplies
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Can not get the ink cartridge out
Jan 14, 2008 | Lexmark X83 All-In-One InkJet Printer
Error 1200, printer carrier stall
check printer belt for missing teeth if none are missing lubricate carrier bar(big siler bar that ink cartrides trvel along) with 3in 1 oil with power off then back on to retry
Jan 06, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark X1150
"Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
Nov 16, 2007 | Lexmark X1150 All-In-One InkJet Printer
Ink Cartidge reset
I ahve the same problem can anyone help it keeps slamming !!!!!
Nov 07, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
546 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
