Question about Watches
How to turn off the alarm on the g-shock 3147
Alarms 1&2 i just seem to turn off. how do you turn them to off..?
  • Watches Master
  • 18,424 Answers
Here is the manual look on page 7 for alarm settings
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3147.pdf
Posted on Jan 20, 2013
SOURCE: Alarm Problems for timex wr50m
hold down the "adjust" button (bottom right) as you press the "start/stop" button (top right). this will cycle through the alarm functions. I believe one is an hourly chime and the other is the alarm. just keep pressing until there are no icons below the time. that should do it.
Posted on Mar 12, 2008
  • 13433 Answers
SOURCE: watch alarm
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
SOURCE: Do not know how to
I had the same nagging problem on my GSHOCK 2816. The Casio manual was no help at all. What I did to turn my alarm(s)  (mine has 5 independant alarms) off is switch to alarm mode (as you are looking at the face of the watch, it's the bottom left button. I push it twice to get to alarm mode. My display shows the current alarm time, and then the number 1. If you hit the top right button on the watch, it turns this alarm off. If you hit the bottom right button, it cycles to the next alarm in the list. To set an alarm, just cycle to the one you want, and then hold the top-left button until you see it flashing, then use the right side buttons to adjust the time. Hope that helps. This was a big pain in the **** until I figured it out.
Posted on Nov 07, 2008
  • 2501 Answers
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Posted on Mar 18, 2010
  • 2501 Answers
SOURCE: how to turn off alarm on g-shock casio watch
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Apr 18, 2010
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
c. }}}} = Daily alarm on only
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
NEED AQUALITE MANUAL - CAN'T SET TIME
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
Apr 09, 2010 | Watches
I can't turn off the alarm. Please help
to turn the alarm off press the mode button until alarm 1, 2, or 3, appears (as required).
Press the start/split button to turn off the alarm.
Jan 20, 2010 | Timex Lavendar Ironman #T5E971 Watch for...
How do you set the time?
To set time:
To set Alarm time:
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Jan 13, 2010 | Watches
I accidentally hid
To make the alarm appear press the button at 8 O'cloc.
To turn off/on the alarm press the button at 2 O'clock.
Jan 05, 2010 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Need to learn to make adjustment on my watch
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C__ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached. (makes higher pitched beep)
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 11, 2009 | Watches
I can't turn the alarms off on my Casio GW-330ca
Setting CASIO G-Shock Watch 1) Home City
3) Adjusting hands
4) Alarm set/on/off 5) Snooze 6) Hourly Chime A --- B ( ) Button reference C __ D
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
5) Snooze (SNZ) Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To stop any alarm, press any button. To cancel next snooze, Press C and go to either the timekeeping screen or the snooze alarm screen.
6) Hourly Chime (SIG): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
May 09, 2009 | Casio G-Shock G2600 watch
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
Watches Logo
169 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
