Question about Singer Touch Sew 7462 Mechanical Sewing Machine
Slow needle at the start and stop of sewing
When I start sewing the needed is hard to put into the fabric and when you stop sewing it studders to come back up
SOURCE: Skipped stitches, but only certain spots
Maybe wrong kind of needle; universal usually works for all, but not always, ball point for knits and sharp for woven.
Posted on Apr 19, 2008
bargainbox
  • 1388 Answers
SOURCE: bunching under fabric and needle stops
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 01, 2009
Testimonial: "thank you that is alot of info. i ended up fixing it before i got your message but all that info will be alot of help and i thank you."
bargainbox
  • 1388 Answers
SOURCE: under fabric bunches of thread and the needle stops after seconds
TOP THREAD TENSION:
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
Bargain Box
Posted on Sep 02, 2009
SOURCE: I have everything in place to sew, the needle is
Try turning the machine off, using the hand knob on the side to lift the needle up as far as you can, then remove your fabric. You'll probably have a nice knot at the bottom where the bobbin is. Cut the fabric loose and rethread everything. My Kenmore would overheat and do this after a few hours of sewing. At this point, it seems like it's just jammed with fabric/thread. I would recommend first unjamming it. If it doesn't sew correctly after being unjammed, refer to the other posters recommendations.
Posted on Sep 21, 2009
  • 255 Answers
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Posted on Jan 26, 2010
What makes stitches skip?
Skipping stitches is usually the needle choice. OR if could be blunt (needles are supposed to be changed every 8 - 10 hours of sewing) There are needles to be only used for sewing stretch fabrics, these are the "blue needles" of ball point needles, then there are the Universal needles for sewing woven fabrics cotton etc. then there are needles only for sewing denim.
You will need to identify which fabric you are sewing and use the appropriate needle.
Then there are the sizes #12 #14 #16 or 75 80 or 90 I'm not sure which numbering system you are using the smaller the number the finer the fabric is the usual way to go..
Also check that the needle is in the correct way. The scarf (the flat side of the needle is to be facing the back of the machine) also check the bobbin as it too can be put in the wrong way and will even try to sew..
Check that your threads are suitable for the fabric If possible try and match the thread in the bobbin with the top thread type.
If all else fails go and have a cuppa and come back to the machine change the needle change the bobbin change the threads and most times it will be ok. cheers Dot
Sep 23, 2015 | Sewing Machines
Needle stopped penetrating my fabric
you need to replace the needle again, is the needle the right one for the heavy fabric?
Dec 10, 2014 | Sewing Machines
Keeps breaking needles
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
Dec 08, 2014 | Sewing Machines
Why would hand wheel be binding or stopping sew machine in one area
Needle may be having a hard item getting through a thick wad of fabric -- use a heavier-size needle. Or, threads have bunched up and need to be cut to release the machine. Check the underside of fabric for bunching threads in that case -- and adjust your top tension.
Dec 10, 2013 | Kenmore Sewing Machines
My singer HD 110 will sew a bit then suddenly the needle will slow down to a stop & the handwheel seems stuck, yet the motor is still running.
Hello there! Make sure your pattern selector is compatible with the presser foot. Good idea to test with a straight stitch setting: Tension: 4. Width:4-5. Length 5 after you insert a new needle and re-thread machine. Your previous needle may have become bent when machine malfunctioned. Use fabric compatible with needle size. Always raise presser foot when threading! Then always lower presser foot before sewing. Remember to use blue tip scarf needles with synthetic fabric silk thread 50. Purster thread 50, mercerized cotton thread 50-60; #11 or #9 for fine or lightweight fabric with silk thread 50 or fine Pollyester thread; #18 leather needle for leather, #14 - 16 denim . Jimmy Sweep out shuttle carefully with small brush for broken threads and lint.
Mar 31, 2012 | Singer Sewing Machines
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
I couldn't find the Brother XL-3520, so I'll just ask here. I noticed that I have a single needle (already attached to machine) and a double needle attachment but I need a thicker needle for...
most domestic sewing machines use 130/705h system needles - buy a pack each of size 70, 80, 90 and 100 to start. if you plan on sewing knits (stretchy) fabrics then buy a couple packs of ball points in size 70 and 80. put in a new needle for each garment you sew as a needle goes blunt in about 6 hours depending on what you are stitching. visit www.sewing.about.com and check out sewing machines 101 and debbie's article on sm needles for more good info. depending on what your heavier weight fabric is you may need to use a 110 size to handle it. the denser the fabric the bigger it needs to be.
May 17, 2011 | Brother XL-3510 Mechanical Sewing Machine
Machine stops sewing when I hit a thickness
it may be that your motor belt needs tighening or the belt may be damaged - you can check belt and adjust tension yourself once side cover is removed.
if you are sewing thick seams and the needle is resting on the seam as you begin to sew you may have to help the machine to get started. if the fabric is not thick it must be belt tension.
scott.
Jun 17, 2009 | PfaFF Hobby 4260
My machine will not sew
When sewing anything that is rubberized you should use silicon spray this will help the fabric move along and will keep the needle from accumulating the rubber buildup and sticking in the bobbon casing.
May 20, 2009 | Sewing Machines
Singer Touch  Sew 7462 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
