Question about Hitachi 12" Compound Miter Saw with Laser Marker - C12FCH
Hitachi C12FCH 12" Laser Compound Miter Saw manual
  • 109 Answers
SOURCE: My Hitachi 10" miter saw laser beam has stopped functioning
Have you tried new batteries first?
Posted on Mar 27, 2009
  • 33 Answers
SOURCE: I have a Hitachi C8FB2 compound miter saw that the
there is always going to be some sparking between the BRUSHES and the commutator. if it is excessive and loud or is really heating up the housing, there could be a crack in one of the brushes, the brush might be chipped or unevenly worn, or the brush holder itself may be burned cracked, or otherwise need to be replaced. they may LOOK okay but need to be pulled out to really know for sure sometimes. there is a small set screw in the housing that holds the brushholder in place.
while this could be the problem with the electric brake, it is more likely that there is a wiring connection loose, broken or burned inside the motor housing. it could be the switch but i dont believe the brake circuit runs through the switch on this model.
Posted on Dec 14, 2009
  • 4 Answers
SOURCE: 12" Compound Miter Saw with Laser Marker - C12FCH: Electronics including the laser marker do not func...
Some lasers work off batteries. If yours does, you might want to change the battery/batteries.
Posted on May 20, 2010
  • 1388 Answers
SOURCE: Electric Blade Brake is not
Brake is controlled by the switch. There are two switches that can be used on your saw. One switch has only on/off, the other switch is on/on. On motor when pressed and on brake when released. The switch with brake does not last very long because the braking action is really just shorting motor circuit (short circuit). All motors can produce electricity. The brake action occurs by shorting motor thru switch. Electricity that motor is producing while turning forces armature to stop. Other brands use a resister in breaking system to absorbe current help switch last longer. Parts are available at www.toolpartsdirect.com Good luck
Posted on Sep 07, 2010
SOURCE: C10FSB 10" Sliding Dual Compound Miter Saw: how to repair brake...
Replace the Stator!
Posted on Sep 14, 2010
Skil Compound Miter Saw laser quit working, Help
SKIL 10" Compound Miter Saw 3317-01
www.skiltools.com/Tools/Pages/ProductDetail.aspx?model=3317-01 Skil10 In. Compound Miter Saw with Quick Mount System and Laser Cutline. Model #3317-01 ... manual Get Manual (PDF); parts list Get Parts List (PDF) ...
[PDF]Operator's Manual 10 in. COMPOUND MITER SAW WITH ...
c.shld.net/assets/own/00921236e.pdf
Dec 14, 2015 | Skil Saws
The laser stopped working on my Hitachi C12LSH miter saw. Now I need to determine whether the laser burned out or if there is another problem. I need to know if the laser works on 120 volts so I can t
clean laser and wire, also clean circuit board and heat circuit board wit the heat gun. if it will not work please relapsed laser. laser not work on 120 volts. laser work DC volts.
Oct 21, 2014 | Hitachi 12" Sliding Dual Compound Miter...
New hitachi miter saw can't loosen the clamp lever
Any answer to this question? We are having the same issue.im sure it's something I'm not realizing but need to get this thing unstuck
Apr 14, 2013 | Hitachi 12" Compound Miter Saw with Laser...
The laser marker quit working - which parts to buy?
Hello. The C12FCH laser unit is housed in the base of the saw housing and has a part No. 323-647. Just a quick check though, are you sure it's the laser module itself and not the laser switch? And have you checked that the lens is free of obstruction? Here's a link to the parts list (blown up, not in fine print like in the manual): http://www.hitachipowertools.ca/upload/fmproduct_filec/C12FCH_BD_6745.pdf
Hope this helps, don't forget to rate us for assistance.
Thank You.
Richard
Mar 20, 2011 | Hitachi 12" Compound Miter Saw with Laser...
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
Does Hitachi C12FCH cut Aluminium?
Hello. A muli-answer for this I'm afraid. The quick answer is yes depending.
Depending On:
  • Thickness of material
  • type of blade
If you are simply wanting to cut aluminum siding/soffit, then install a paneling blade backwards and chop down slowly
If you are referring to bar stock, you will - but not well. You will need a special quick-cut abrasive blade, and you may find you need to change the blades often.
If you wish to cut screen door trim, curtain rod, draft stop, Jolie Edging for ceramic tile, or other thin hollow/extruded materials - then the abrasive blade will do nicely for short/small jobs.
The main problem with cutting aluminum in a high speed rotary device is that the friction of the blade heats the metal fast enough that you get a coating on/in the blade. (In layman's terms - bunged up) The devices in machine shops are set considerably slower, and are usually cooled mainly with liquid.
Hope this answers your question satisfactorily. Good Luck and don't forget to rate this answer.
Thank You,
Richard
May 27, 2010 | Hitachi 12" Compound Miter Saw with Laser...
May 17, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Saw quick working suddenly, maybe blown fuse
Your saw will have a reset button that may be black in color but should not have a fuse
With the power off push down in the reset button you may or may not hear a small "click" plug it back in a give it a try
Pushing them to hard will cause an overload and they will quit
give it 5 minutes to cool of and resetting should do it
Mar 08, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Hitachi 12" Compound Miter Saw with Laser Marker - C12FCH Logo
106 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
