Question about Samsung LN-S4051D 40 in. LCD Television
Power wont come on... red light blinks... hear clicks but no pix
Same problem all these folks are having........ I have taken back cover off and I am wondering if it could be this fuse where the power is coming into the board. Samsung TV won't turn on- trying to fix it. A... var g_tryMail = 0; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse shared by 5 users posted by xiangr on Jun 17, 2008
Gurus, help needed on fixing a Samsung LCD TV (LN-S4051D). The 1.5 year old TV won’t turn on. There is no picture or sound. When plugged in, a click sound was first heard followed by the red LED light blinking 4 times (next to the power button on the panel). Then the click sound came back again with 4 blinks of the LED light. The whole thing went into a cycle while the power button on the panel and the remote are not functioning.
I did some research and followed the suggestions on a “similar” problem brought on this forum. I replaced the IP board (power board) with a new one. The problem still existed. Then I checked all the capacitors on the PCB board (the main board) and found no blown ones. My question is that what is the real problem of the TV, and if it’s worth to spend another 300 dollars to replace the PCB board. (I already spent over 100 bulks on a new IP board). BTW, the TV cost me 1300 dollars when I bought it. Thank you all, // '); }// ]]> I Can Solve This! I have the same problem Post a new problem
I know someone who can solve this problem X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 4 Other Users Have The Same Problem Posted by Guest on Sep 01, 2008 I actually have the same exact problem, I've been reading and there is no other way than replacing the main board. Anyways, since the TV is 1.5 years old, Samsung won't honor warranty.. we should fight it together, this is an actual recall there is no way this is happening and none of us do nothing.... Posted by Guest on Aug 27, 2008 I have exactly the same problem that was reported by xiangr on Jun 17, 2008. Same make, same model, 1.5 yrs old, four blinks cycling over and over again but TV never comes on. Our problem started on August 17, 2008. Have not tried anything other than internet to see if there are similar problems Posted by aurelius1 on Aug 06, 2008 Same deal with my 4051D, it clicks intermittently while plugged in. Does not respond to remote control other than to make more clicking sounds when certain buttons are pressed .. strange.
Please e-mail solution or advice to me. Posted by Guest on Jun 23, 2008 I have the same problem. Anyone knows how to fix it?
  • 5 more comments
  • womble137 Jan 30, 2009
    I also have this problem, when it first started it came on after 5 mins then next day 10 mins then 20. Today ive been sitting here for 2 hours. clicking is driving me up the wall
  • phatom1 Feb 06, 2009
    I have been clicking for 2 days now. This TV is junk
  • yoli619 Feb 13, 2009
    This is crazy!! We have the same problem. Just started today, and has been out all day. Our TV is the same exact age a little over 1 yearsold, and the same clicking issue with the red light. I am calling Samsung to see how to start a possible recall. Lets do this together!!!
  • dana_r Feb 17, 2009
    Add me to the list guys. I am starting to think that it is a time bomb, just out of warenty and poof. LOL..got a 1980's sylvania console in the garage that is still running strong go figure.
  • mjb3 Feb 20, 2009
    Same issue....at first it did for only a little while, once it even came back on by itself for a couple of hours, now its done, it will not come back on.
  • andyhock2009 Mar 02, 2009
    same prob click click click red light ............nothing????????whats the issue please help
  • Anonymous Mar 05, 2009
    I have the same problem. TV clicks but doesn't turn on. Need help!
  • 335 Answers
There are many reasons as to why the tv can default to service mode (blink codes) and may have nothing to do with the power supply board. Flat panel tv technology incorporate intuitive interrupt circuits designed to prevent catastrophic failure regardless of the boards functionality.
Some root causes to this condition may be:
1 Bad inverter board (step-up hi-voltage CCFL)
2 faulty regulator control board (data timing)
3 faulty interface processing board(s) (signal switching)
4 faulty power supply board (main voltage)
5 Bad LCD driver circuit, or faulty LCD panel its self.
6 faulty scan circuits.
__________________________________
To diagnose and solve these particular circuit scenarios require a professional service technician. Any of the problems above would take around 35 minutes and 100 bucks to repair at a service center.
But if you insist on fixing it yourself I can try to help you determine which board is possibly defective. I do have schematics for this chassis. If you have a multi-meter and 5mhz oscilloscope we can get started. These are the 2 instruments needed to check for critical waveforms and voltages according to the schematic data. It could be any circuit in the tv causing this condition.
The components on the circuit boards that could be defective are as follows:
Diodes
Transistors
Inductors
Resistors
Transformers
Crystal oscillators
Filters
Relays
Transducers
Capacitors
IC chip arrays
__________________________________________
Modular causes to this condition may be:
poor resistance too ground
high current too ground
over voltage
under voltage
over current
under current
shorted switch actuation
___________________________________________
Software related blink intervals:
Parental locks
Sleep mode
Hidden key commands (test mode servicing)
"though if in this blink category the tv should come on requiring password. So this is unlikely....
Posted on Jan 26, 2009
  • 98 Answers
If pound the broken fuse, need to exchange the IP Board
but sometimes the Main Board problem happen 70%
Posted on Feb 06, 2009
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Set is getting power, but no sound or picture. we purchased it black friday
Power supply issue such as bad caps etc. But need the model number of the set in order to assist further.
Feb 08, 2012 | Hisense Televison & Video
TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
Oct 18, 2009 | Hitachi 50V715 50" Rear Projection...
Samsung TXN2668WHF Does not power on, blinking red light
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 10, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Samsung LN-S4051D 40 in. LCD Television Logo
829 people viewed this question
Henry  Thomas
Henry Thomas
