Question about Casio G-Shock GW500A-1V Wrist Watch
How to turn off the alarm on the g-shock 3147
  • Dwight Hagley
    Dwight Hagley Jan 19, 2013
    To save sleepness nights and days press the red alti meter button.. it wasn't over obvious..
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
Alarm setting I want to set an alarm to repeat daily as a alarm clock would for a g shock
casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left ...">casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. ...
Mar 10, 2011 | Casio Watches
How do you shut off alarm on g500a watch
Use the mode button to switch to the alarms. Use the Receive button to scroll through the alarms until you get the one that you want to turn off. Press the Time Memo button to toggle it on or off (you'll know it's on when the pie piece in the 3 o'clock part of the right-most circle is lit and it's off when that pie piece is unlit.) Use the same method to turn an alarm on by toggling the alarm to the other setting.
Feb 19, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How do u turn off the alarm on a baby g shock. Like how do u turn it off forever?
mcdevito75 Here, You should be able to reach the alarm thru the MODE cycle, Press MODE and see Flashing display, press Mode for each function till you reach alarm and put alarm to off, if you have t1 and t2 time you"ll have to do this twice.
Oct 26, 2010 | Casio BG191 1B2 Baby G Watch
How to turn off alarm on g-shock casio watch
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 18, 2010 | Casio G-Shock GW500A-1V Wrist Watch
I can't turn off alarm on casio g shock
Follow this link: http://world.casio.com/wat/download/en/manual/ Download manual for your watch and read how to turn alarm off.
Jan 12, 2010 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
C __D
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Do not know how to turn alarm off on casio g shock watch
I had the same nagging problem on my GSHOCK 2816. The Casio manual was no help at all. What I did to turn my alarm(s)  (mine has 5 independant alarms) off is switch to alarm mode (as you are looking at the face of the watch, it's the bottom left button. I push it twice to get to alarm mode. My display shows the current alarm time, and then the number 1. If you hit the top right button on the watch, it turns this alarm off. If you hit the bottom right button, it cycles to the next alarm in the list. To set an alarm, just cycle to the one you want, and then hold the top-left button until you see it flashing, then use the right side buttons to adjust the time. Hope that helps. This was a big pain in the **** until I figured it out.
Apr 17, 2008 | Casio Watches
Casio G-Shock GW500A-1V Wrist Watch Logo
48 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
