Question about Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile
No Steering for Arctic Cat 18" RC Snowmobile
We purchased an 18' Actic Cat RC snowmobile for my son. There has never been a "reverse" on it, but that is not a problem. The steering doesn't work, and I'm hesitant to try to take the front-end apart to try to fix it. I can get the screws that hold it together out, but I can't get the "hood" off for fear of breaking something important made of plastic that will destroy it permanently. From what I can see inside, the housing that holds the plastic gears together is cracked on the front -- small but enough to make everything inside the housing loose & sloppy so the gears won't mesh. That allowed the shaft that one of the gears spins on to come out. If I can get the fron't end off I may be able to fix it. any suggestions?
I have the same sled. The steering has 3 gears conected to a drive motor. There are 6 screws that hold the hood on. Two right on the bottom of the sled. There are 2 more that hold the front bumper on. Than two more that is kinda hidden just in front of the steel bulkhead plate.
Once you get them out the hood should come off. Do not pull it all the way out, there are wires that go to the switch and the headlights. Now if you have the hood off, if you are looking athe inside of the sled there are two black box covers that are held on by 4 scerws. From the front of the sled the cover on the right is the steering cover. That it off and look at the gears. Maybe you can glue the box to hold the gears better. To my knowledge they do not sell replacement gears for the steering or any other parts. I think you can get the controller or new skis but that is about it.
I hope that helps.
Good luck
Posted on Feb 12, 2009
Pulled the plug wire off the right cylinder and it killed the engine
Electrical Diagnosis for Arctic Cats - YouTube
? 9:58
https://www.youtube.com/watch?v=iwwl4LPyOCY
Dec 29, 2009 - Uploaded by BlaineDP
When in the "OFF" position the switch will ground the ignition wireto the chassis effectively "grounding out" the ignition systemkilling the spark. ... becomes disconnected or if a wire gets cut then the switch will no longer turn off the engine. ... Testing a stator in a snowmobile Arctic cat - Duration: 3:25.
CAT AS NO SPARK!! - American Snowmobiler Magazine ...
cs.amsnow.com > ... > Forums > Manufacturers > Arctic Cat snowmobiles
If the connection to any switch; key, kill, tether, throttle safety switch, etc.. is ... Some older model Arctic Cats have the ground up closer to the handle bars on ... Here is a general rule of thumb for putting spark plug wires on which cylinder for Cats: ... Pulledthe ECU cover off and found some corrosion; I had a 580 that did not ...
Jan 16, 2016 | ATVs
Need to find replacement for broken belt/track.
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Oct 24, 2010 | Interactive Toy Concepts Crossfire Arctic...
New 2007 arctic cat 400 4x4 13 miles,backed fired now want star
Take the carburetor apart and clean/ inspect it. It is possible that the slow jet was not put in securely, and dropped into the bowl. just reinstall it. You could have a choke plunger that is sticking open.
Apr 14, 2010 | Interactive Toy Concepts Crossfire Arctic...
Have a 94 wildcat 700 and is running of 1 cylinder need help
check the spark on the dead cyylinder, if there isnt any, replace the coil, this is the little box that the sp wire goes to
Feb 11, 2010 | Interactive Toy Concepts Crossfire Arctic...
I was recent given an arctic cat ''jag'' snow mobile and don't know ghow to find out what year it wass manufactured.
Look for a tag on the side of the snowmobile tunnel that says what year it was made. You will typically have to add 1 year to the year that the tag says.
Feb 06, 2010 | Interactive Toy Concepts Crossfire Arctic...
Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile Logo
976 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
