Question about GE SpaceMaker Microwave Ovens
Ge microwave model jnm1851sm2ss isn't working
Ge microwave model jnm1851sm2ss it acts like there is a short in it somewhere ...like at first the lights blinked on it like the timer light ... then my son tapped the micro and the light inside became REAL BRIGHT that lasted a few days then the INSIDE light went OUT!! BUT the mirco still worked........ then yesterday it just went out all together .......... LIKE THERE IS NO POWER TO IT ..... dead..... then for no reason last night the timer light came on with like all 000000 ...then went off again .... I DON'T understand what it is
jsrock516
  • 5911 Answers
SOURCE: XL1800 GE Spacemaker Microwave oven "dead"
It's not good to run ANY microwave with the oven cavity empty. The items you place inside to cook or heat up act as a "load" and help to absorb/dissipate some of the RF energy. Your microwave has several thermstats installed that will blow in an overtemp condition. If you're lucky the Magnetron is still intact and only a thermostat has failed. The thermostats are small cylindrical devices mounted near the magentron and the oven cavity. They act as fuses and must be reset if blown. Go to geappliances.com and select "Parts & Accessories". Go the bottom of the next page and type in your model number. On the Search menu page select the second menu and type in "thermostat". There will be a series of thermostats listed with helpful drawings on where to locate them. I would advise you to check these drawings first and see if you can locate the thermstats to determine if they are bad. The thermostat should read a short (or very low resistance) if it is good. The part numbers are as follows:
Duct Thermostat (Item 27) ----------WB27X10714
Plate Thermostat (Item 115) ------- WB27X10713
Bi-Metal Thermostat (Item 110)-----WB27X10788
They all cost about $15.00 a piece.
Some additional advice: Make sure you unplug the microwave before servicing. If you are not savvy when it comes to electronics, or have never worked on a microwave before, it may not be adviseable to work on this yourself. Voltage potentials inside the High Voltage section of a microwave oven (where the Magentron is located) can be dangerous. There is a large capacitor that can store a charge and can be a shock hazard.
I hope this isn't discouraging to you, I just wanted to make you aware of some of the possible hazards associated with this appliance. I hope you find information helpful, and let me know if you need further assistance.
PS The alternative if all the thermostats are good, would be to check and/or replace the magnetron. (Item 73, Part #WB27X10305 at $115.00)
Posted on Apr 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker XL14, night lights won't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Goldstar Microwave - Digital display is dark & does not operate
I would suspect the oven cavity thermostat is open.
We have a similar model's service / repair manual and have uploaded it to our site here for free download to help you with disassembly & troubleshooting.
To order Goldstar / L.G. parts, visit Encompass. Since l.G. / Goldstar does not list part numbers in their manuals, you'll probably have to call Encompass toll-free at at 866-779-5835.
Posted on Jan 31, 2010
fathitkf
  • 1871 Answers
SOURCE: GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Posted on Mar 29, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: Ge Over The Range Microwave Oven JVM2050...5 yrs.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Posted on Jun 20, 2010
Flame Sensor not available
We could look it up if we knew your full model number, but some of their budget models (like some made for Wal-Mart) are made with only turntable parts available.
Within the warranty period, the oven is to be returned to the dealer.
But a fire would not normally be covered under warranty unless the oven came on by itself when idle.
Otherwise, the thermostat / TCO has temperature markings on it, and a generic equivalent or very close type can be matched at a local appliance parts store.
May 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Moisture between glasses on door. Is it dangerous to use it in this condition?. I have a pace maker and I do not want to damage it My microwave is only a year old.`
Since microwaves act directly on moisture, this should tell you that it isn't causing any leakage from the cavity/cabinet of the unit. If microwaves were passing through the moisture, it would eventually dry out completely I don't believe there is any reason for concern.
Even bad gaskets (seals) around the edge of the door do not cause leakage. Only a mechanically bent door could cause this and it would still be very minor.
The cooking enclosure itself is what is called a 'tuned cavity' and as such, contains the bulk of the energy internally.
Sep 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When I plug the unit into the outlet, the GFI pops up
There is a short internally in the microwave somewhere... the GFCI checks and see the short and immediately trips out...
You will need to use an OHM meter and check out the circuitry to find the shorted place inside the microwave...
heatman101
Oct 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
Panel periodically acting up - says there is a short in the panel
Hello there:
what this is trying to tell you is that your control panel is starting to go out due to a failure in the controle assembly
yes it is feasable to replacethe panel youwill just have to contact the manufacture of the microwave and get a replacement panel/ controle board ok
I hope that this is very helpful for you
Best regards Michael
Nov 21, 2009 | GE Profile Spacemaker Over-the-Range...
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
May be a shorted door switch or possible bare wire somewhere that is grounded which is rare. Would suggest using an experienced technician check it due to high voltage.
Oct 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
257 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
