Question about Kenmore Sewing Machines
I have a Kenmore Model 1247 and haven't used it in a while. When I try to sew only the hand wheel moves.
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
louislevel_2
  • 374 Answers
SOURCE: needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Posted on Mar 15, 2009
  • 240 Answers
SOURCE: My Kenmore sewing machine model 385.15212 is stuck
I doubt it is a motor problem but it is too jammed up to turn the motor-you are right not to force it. Take out all of the bobbin parts again and leave them out. Now unscrew the needle and while lowering it, into the needleplate hold it tightly and remove it. Clear all thread from the machine and it should now move freely.
Reassemble the bobbin parts and reinsert a new needle being careful to insert it fully and correctly.
Posted on Jun 11, 2009
  • 96 Answers
SOURCE: Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Posted on Dec 13, 2009
The needle on my model 1315 Kenmore sewing machine wont go up and down.
try turning the bobbin in the opposite direction & see if that helps
Jul 30, 2012 | Kenmore Sewing Machines
Should the wheel on my Kenmore Sewing Machine 385.19233400 be able to move in both directions?
usually no, most machines you can move the wheel a little bit backward but shouldn't. just turn it towards you.
May 09, 2012 | Kenmore Sewing Machines
Hand wheel & needle do not move
it's possible that something has come loose or broken on the inside of the machine.
the name & model number of the machine is not shown, if the machine is mechanical it probably has a handwheel clutch,, make sure the smaller inner knob is tight. then try to sew again
if you still can't sew then I suggest you have the machine checked, because it's not reponding like it should
Apr 01, 2012 | Sewing Machines
Brother sewing machines lx2500
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster i need help to :{
Nov 25, 2011 | Brother LS-2125 Mechanical Sewing Machine
Kenmore model # 11607090 older model, been setting up for several years, but has never been used-cannot unlock the hand wheel. we were able to wind bobbin, but wheel will not turn.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Sep 05, 2011 | Kenmore 1667 Mechanical Sewing Machine
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
Dec 12, 2009 | Kenmore Sewing Machines
Im trying to sell a Kenmore 117 - 959 but I can't get it to move. There is power to the work light, but Im stuck. Help!
If your gaskets are bad, the machine will not rotate. Can you move it by hand? If not then have you checked the gasket in the back of machine that comes in contact with the hand wheel? If it is making contact, this is what runs the machine and both the little black gasket and the hand wheel will spin when you rotate by hand. If the hand wheel is free spinning then it may need oiled. If you have a manual, try oiling the complete machine according to manual.
Jul 10, 2009 | Kenmore 11101 Mechanical Sewing Machine
I have a Kenmore 1516 that will not sew. The
If you can take the top cover off, try spraying the whole machine works with WD-40. Let it sit for a few hours to start working and then try to move things slowly.. If things start to loosen up but not totally move, spray it again and let it sit over night and try things again.
Kelley
Apr 26, 2009 | Sewing Machines
Sewing Machines Logo
71 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
