Question about Gateway ZX6961 All-in-One Computer - Intel Core i3 i3-2100 3.10 GHz - Desktop -
How do I remove the back of my gateway all-in-one
Remove top
To me when you state remove the top of a laptop, you are talking about removing the Palm Rest Cover.
With the laptop closed, the top cover is the Display Cover.
This, I suppose, could be considered the 'Top' also.
At any Ol' rate here is the link to a free Service Manual, for the Gateway NV53 series of Notebook PC's.
I think you'll find it crosses directly over, to the Gateway NV52 series of Notebook PC's; which you have one of,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Go to the top line - Gateway 400. (400 in blue)
Drop down to the second line, scroll over, and click on the blue -
NV53
Now you can disassemble the Display Assembly, or remove the Palm Rest Cover.
If it is the Palm Rest Cover post back in a Comment.
The reason is I want to give you needed information.
The main one is the Keyboard Cable connector on the motherboard.
IF you break that ZIF connector, you are looking at MOTHERBOARD REPLACEMENT, and why I want to guide you.
(Or any of the other ZIF connectors on the motherboard.
Zero Insertion Force)
A) http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Gateway NV52L06u Laptop PC
Gateway NE56R
1. Flip your unit over to its back and remove the battery.
2. Remove the screws on the large cover and remove the cover.
3. You will find the memory and hard drive under that cover.
P.S you should use a static guard to remove any of those parts.
Hope this helps
Feb 18, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
How to remove back of gateway zx6971
try this manual http://support.gateway.com/product/default.aspx?modelId=3931
Jan 18, 2013 | Gateway Computers & Internet
Remove back of gateway model zx6971
in this link you can find and download the manual that can help, you http://support.gateway.com/product/default.aspx?modelId=3931
I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 21, 2011 | Gateway ML6230 Notebook
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
How Do I remove the cover from a Gateway 500 series???
Like this Gateway SE?
http://support.gateway.com/s/PC/2800071/280007101.shtml
On the back of the computer remove the screw from the top middle.
Now remove the screw on each outside edge, down towards the bottom.
Hold the outside shell, or computer cover. Push the inside forward.
The computer cover comes off like a shell, or bonnet.
http://support.gateway.com/s/PC/2800050/280005003.shtml
If this is a reference to a Gateway 500X series, remove the thumb screw/s from the back of the computer, on the right side. (Right side as you are facing the back of the computer) Then slide this Side Panel towards the back of the computer.
Regards,
joecoolvette
Dec 19, 2010 | Gateway 500 X PC Desktop
Remove back panel on gateway plasma tv
jeff
I just took the back off my Gateway for a simular problem
I just took the screws out of the legs on the back of the set and all the screws around the edge then the support where the legs were attached and then the screws around the box with all the video jacks that pulls off. Hope this helps
brucep63
Mar 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Removed realtek and now have not sound. how do i get it back?
GO to the gateway website. Put in you 10 or 22 digit serial number and download the audio software and driver.
http://support.gateway.com/support/drivers/dlcenter.asp
Feb 23, 2009 | Gateway GT5028 PC Desktop
Disassembly of Gateway 610
Found this - should help you
cosmetic screw covers that cover nothing
"remove this panel so you can remove that panel so you can slide the
carriage holder and unscrew the fenortnor rods."
"Flex the case in the middle and the undercarriage will drop out."
"Slide the front cover a couple inches left and remove screws, then
turn it around and lift the cover one inch to remove third screw."
Dec 31, 2008 | Gateway Media Center 610XL PC Desktop
Gateway ZX6961 All-in-One Computer - Intel Core i3 i3-2100 3.10 GHz - Desktop - Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
