Question about Motorola Mobility Motorla MOTXT912 DROID RAZR Verizon 4G Smartphone
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Its charges back ip to 50% within minutes but dies in minutes after one call its dead
    Master:
  • 520 Answers
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Jan 20, 2013
Franky_J
  • 15 Answers
SOURCE: My RAZR *v3* Drains a good battery in 15 minutes
Go to your provider and have them install a current software version for your phone.
Posted on Nov 25, 2008
SOURCE: Battery Too Dead to Charge?
The issue is probably not the battery but the charging port. I'm having the same issue. I happen to have Motorola Phone Tools on my computer. It works with the W385 but sometimes doesn't recognize the phone. Battery has 2 bars. If I wiggle the cord, it will recognize it. Then 4 seconds later, lose the connection. I already replaced this phone 5 months ago for the same issue.
I think the problem is the charging port is not working.
Posted on Jan 21, 2009
  • 53 Answers
SOURCE: Fully charged cellphone battery drains in a few minutes
relpace your mobile battery and avoid overcharging and charging overnight
Posted on May 22, 2009
ipsbatra2002
  • 3 Answers
SOURCE: Can't charge a dead battery / ALSO call reception is bad.
this is minor problem . battery nu zatka (current) externally lagao .set thik ho jaouga..
Posted on Aug 07, 2009
  • 63 Answers
SOURCE: My razr will not hold a charge. Changed the
The charger is bad, not supplying enough current to bring the battery to full charge.
Or your replacement battery is bad.
There is a small possibility that the charging circuit inside the phone is bad.
So, before you spend money on a charger, see if someone will lend you their charger and let the phone charge over night. If it holds a charge then you know the charger is bad.
Good Luck!
Posted on Jan 03, 2010
Testimonial: "I tried charging it on my laptop. Will see. But I have had this problem almost from the beginning.Thanks for the info."
Why doesn't the motorola P4000 not hold a charge after charging it for several hours
Your battery is shot. Rechargeable batteries only last so long.
Feb 08, 2015 | Motorola Cell Phones
Cannot turn on
from https://discussions.apple.com/thread/2462356?start=0&tstart=0
Try pressing SLEEP/WAKE button and HOME button *at the same time* to force it restart for 2 or 3 times and see if it can turn on. Sometime it's just turn off by itself (happens more frequently for me esp when the battery is low) and we have to force it to start again.
Hope this helps,
Jan 03, 2014 | Apple iPad 64 GB WiFi
More consuming battery every day i charged my galaxy s4
reset the phone to factory.
let the phone die.
charge the phone till 100%
when at 50 % charge again till 100%
let the phone die
Charge to 100%
Nov 28, 2013 | Samsung Cell Phones
Phone has no power and it won't turn on or charge
Take battery out, wait a few seconds then put it back in. Turn the phone on to see if it worked
Sep 19, 2013 | Motorola Mobility DROID RAZR MAXX HD
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
HP DV2500 Battery charged to 100% but dies within minutes
Your battery is done. Batteries only have a useful life, and after that you have to replace them because they will not recharge or hold a charge.
May 30, 2012 | Office Equipment & Supplies
My Motorola V3c will fully charge the battery in about 15 minutes. But the charge lasts maybe 3-4 hours. It is a new phone.
Moto Razr components where taken off the assembly line years ago and all parts used are refurbished or stockpiled.........you have a bad battery, case closed........the razr has a few common flaws...... ear piece, LCD, and battery tends to go out without notice and on a rare occasion wont work right out of the box.....Working at Sprint PCS I saw 1 out of every 15 Razrs have problems straight from the box....take the phone back to the staore and they will giv you a new battery as they should be away of the hiccups associated with this device!!!! :D and by the way, 3-4 hrs use from a 15 min charge is awesome.......just your battery has an internal flaw that is causing it to transfer too much power.....(i.e. thats how it is able to charge so fast, but also why it dies so fast) if you have another razr laying around try that battery as long as the lettering on the battery is the same....fr example : a battery with the code bt50 and br50 are not interchangeable.
Good Luck and pls rate this post!!!! :D
Oct 08, 2009 | Motorola Mobility RAZR V3
Stange battery performance???? - iPAQ h2200
surely the problem is with the battery ask for a replacement, try to find one which has the same mah with the battery you got along with the phone.
Apr 15, 2009 | HP iPAQ H2210 Pocket PC
Nov 25, 2008 | Motorola Mobility RAZR V3
Motorola Mobility Motorla MOTXT912 DROID RAZR Verizon 4G Smartphone Logo
200 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
